USB to RS232 adapter
Results 1 to 20 of 20
    Oct 2003
    Australia
    Yeah your right,
    I guess what I should have said was this.
    I can transmit in only one direction usb->usart, or usart->usb, not in the same program. Never mind now. I'm confused... ;(
    Using Int_18 has def. sped things up!
    Now I can transfer from USB->Usart successfully at 57600 baud, however Usart->Usb still only good enough at 9600 when sending text file. (Sending single key strokes is fine both directions at any speed).
    I figure that the usart buffer needs to be increased as this is the bottle neck.
    Cheers
    I think you'll find that while from USB to USART works fine. It's massively buffered by the PC. If you were to send the same text file directly to a com port at 57600, it would take 1/3 as long to transmit.
    This is because the PIC waits untill the last buffer full of data is sent via HSEROUT, before allowing it to receive more from the USB. The PC does the buffering, instead of the PIC.
    And on the other side of it. This program is only sending 1 byte at a time to the USB. You can send up to 64. If it were buffered at the PIC, it could save incomming 232 data while it's busy sending to USB, then send a larger packet on the next time around. I think this would greatly improve the overall speed.
    Theoretically, you should be able to run quasi-full-duplex at 250kbaud, without any problems.
    Jan 2006
    Toronto
    Squibcakes: Is it possible to get a copy of the source you have working with the DT interrupts? I greatly apreciate all the help you guys are giving me.
    Thanks.
    Oct 2003
    Australia
    Talking
    Sure thing brother,
    Play around with the baud rates and see what max data speed you get. 250K would be awesome! but I think some sought of hardware hand shaking is needed to get up to those speeds. Hahaha
    Anyway, first step I think is to increase the buffer size form 1 char to as DT said, about 64 Chars.
        INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
        INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    '   USB sample program for PIC18F4550 CDC serial port emulation
    '   Compilation of this program requires that specific support files be
    '   available in the SOURCE DIRECTORY!!
    '   18F*.BAS	Device header files that use the USB libraries
    '	CDCDESC.ASM	Descriptor file	for CDC	serial demo
    '	JADESC.ASM	Descriptor file	for Jan	Axelson	demo
    '	MOUSDESC.ASM	Descriptor file	for mouse demo
    '	PBPCDC.INF	INF file for the CDC serial driver
    '	USB.TXT		This file
    '	USB18.ASM	USB assembler file
    '	USB18.INC	USB definitions	file
    '	USB18MEM.ASM	USB memory allocation file
    '	USBCDC.BAS	CDC serial demo	BASIC program file
    '	USBDESC.ASM	Include	file for descriptor file
    '   You WILL also need to modify the
    '   file USBDESC.ASM so that the only line used is -> include "CDCDESC.ASM"
    '   MUST use the 4 MHz xtal for this.
    '   this program receives data via usb virtual port then sends out via serial
    '   usart.
        '   USART module
        Define    OSC     48
        DEFINE    HSER_RCSTA   90h
        DEFINE    HSER_TXSTA   20h
        DEFINE    HSER_BAUD    4800
        DEFINE    HSER_CLROERR 1
        '   USB module
        UCFG    var byte EXT        ' include UCFG register... Yeah Melabs didn't :o(
        ucfg    =   %00010100       ' enable internal USB pull-up, Full speed USB
        '   ANALOG I/O CONFIG
        ADCON1 = 15               ' Set all I/Os to Digital
        CMCON = 7                 ' Disable Comparator
        Buffer    VAR BYTE[16]
        Cnt       VAR BYTE
        B0        VAR BYTE
        INT_LIST  macro    ; IntSource,Label,Type,ResetFlag?
            INT_Handler    RX_INT,_SendUsB,PBP,yes
        INT_ENABLE   RX_INT     ; enable external (RX) interrupts
        USBInit
        ' Main Program Loop
    MainLoop:
        USBService            ' Must service USB regularly
        Cnt = 16
        USBIn 3, Buffer, Cnt, MainLoop
        HSEROUT [STR Buffer\Cnt]
        GOTO Mainloop
    '---[RX_INT - interrupt handler]------------------------------------------------
    ' PROGRAM COMES HERE WHEN DATA ENTERS THE USART PORT
    SendUsB:
            HSERIN [B0]
            Buffer[0] = b0
            cnt = 1
    OutLoop:
            USBOut 3, Buffer, Cnt, OutLoop
    @ INT_RETURN
    Cheers
    Sep 2006
    Venezuela - Caracas
    Default i don't send to pc data recived from pc
    Data of hserin is ok
    Cnt = 10
    ' Send to pc data recived from pc
    GOTO OutLoop <---------not work, not send buffer
    GOTO Mainloop
    INCLUDE "modedefs.bas"
       ' Configuração
       asm
          __CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
                             ;              ;                      ; USB clock source comes from the 96 MHz PLL divided by 2
                             ;              ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
                             ; No prescale (4 MHz oscillator input drives PLL directly)
          __CONFIG _CONFIG1H, _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
                                   ;                  ;               ; Oscillator Switchover mode disabled
                                   ;                  ; Fail-Safe Clock Monitor disabled
                                   ; XT oscillator, PLL enabled, XT used by USB
          __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
          __CONFIG _CONFIG2H, _WDT_OFF_2H
          __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
          __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
          __CONFIG _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L & _CP2_ON_5L & _CP3_ON_5L
          __CONFIG _CONFIG5H, _CPB_ON_5H
       endasm
       DEFINE    OSC 48
       DEFINE    HSER_BAUD    9600
       Buffer    VAR BYTE[16]
       Cnt       VAR BYTE
       A         VAR BYTE
       B         VAR BYTE
       C         VAR BYTE
       PIC_TX    VAR PORTC.6     ' Transmit Pin
       PIC_RX    VAR PORTC.7     ' Receive Pin
       INTCON2.7 = 1             ' Disable PortB Pullups
       CMCON = 7                 ' Disable Comparators
       ' Interrupt Settings
       RCON.7 = 0                ' Disable Priority Interrupts, 1 to Enable
       ' Enable/Disable Interrupts
       INTCON.4 = 0              ' Disable INT0 (PORTB.0)
       INTCON3.3 = 0             ' Disable INT1 (PORTB.1)
       INTCON3.4 = 0             ' Disable INT2 (PORTB.2)
       INTCON.5 = 0              ' Disable TMR0 (Timmer 0)
       INTCON.6 = 1              ' Enable Peripheral Interrupts
       INTCON.7 = 1              ' Enable Global Interrupt Handler
       PIE1.4 = 0                ' Disable USART Transmit Interrupt
       PIE1.5 = 1                ' Enable USART Receive Interrupt
       PIE2.5 = 0                ' Disable USB Interrupt
       PAUSE 1000
       USBInit
       ON INTERRUPT GOTO Main_Interrupt_Handler
       ENABLE INTERRUPT
    ' Main Program Loop
    MainLoop:
       Cnt = 10
       GOTO OutLoop
    GOTO Mainloop
    ' Interrupt Handler
       DISABLE INTERRUPT     ' No Interrupts past this point
    Main_Interrupt_Handler:
       ' USART Transmit Interrupt
       IF PIR1.4 = 1 THEN
          PIR1.4 = 0
       ' USART Receive Interrupt
       IF PIR1.5 = 1 THEN
          HSERIN [A, B, C]
          Buffer[0] = A
          Buffer[1] = B
          Buffer[2] = C
          Buffer[3] = 13
          Buffer[4] = 10
          Cnt = 4
    OutLoop:
          PIR1.5 = 0
    IntDone:
       RESUME                ' Return to main program
       ENABLE INTERRUPT
    ..: Don't worry, be happy :..
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. USB to rs232 emulator
    By Pic2008 in forum USB
    Last Post: - 5th March 2010, 16:54
  3. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  4. Bafo USB to serial adapter
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 29th July 2006, 19:48
  5. USB to Serial Adapter with 9.6v
    By serandre in forum Serial
    Last Post: - 10th May 2006, 21:16
