Thank you for the replay.
I try to control with this code a programmable wave generator. It has a serial interface. The word lengths it accepts is 16.
The problem is that in MPlab when simulation the code is that all my word variable are reprezented as 8 bits. For clarity I'll post the poart of the code related to this wave generator:
' code for driving a Prgrammable Wave generator
'It receives from pic words of 16 bits for configuration
powrez var word
pow var word
i2 var byte
date var word
tmp1 var word
tmp2 var word
len var byte
biti var bit[16]
pinul var byte
f var word
f1 var word
Frec var word
quartz var Word
s9833 var bit
TRISC = %00000000 ;all output
TRISA = %00111111 ;all input
Define OSC 24
start: ADCON1 = 7
high PORTC.6
high PORTC.7
quartz=300
Frec=quartz/2
s9833=0
high PORTC.1
gosub setup9833
s9833=1
'function that computes the 2^pow and store the result in powrez
power:
powrez=1
powrez = powrez << pow
' this function transforms a number (ie 5 ) into a serial array (00001001- for len=8bits, bit(0)=0, ....biti(4)=1, biti(5)=0...biti(7=1)) and then sends this array on the PORTC.2, simmulation the clock on the PORTC.0
sendit:
pow=len-1
gosub power
tmp1=powrez
for i2 = 1 to len-1
pow=len-i2-1
gosub power
tmp2=powrez
if ((date//tmp1>date//tmp2)) then
biti[i2]=1
biti[i2]=0
tmp1=tmp2
next i2
for i2=0 to len-1
high PORTC.0
if (biti[i2]=0) then
if pinul = 1 then low PORTC.1
if pinul = 2 then low PORTC.2
if pinul = 1 then high PORTC.1
if pinul = 2 then high PORTC.2
low PORTC.0
next i2
' this function setup the wave generator (active low)
'the frequency of the signal is transmitted as two 16 bits words (f,f1)
'the other data are control words
setup9833:
High PORTC.0
'pause 5
low PORTC.6
if s9833<>0 then
date=%0010000000000000
date=%0010000100000000 ' chip reset
len=16
pinul=2
gosub sendit
pow=28
gosub power
f=powrez/quartz
f=f*Frec
pow=14
gosub power
f1=f//Frec
pow=28
gosub power
f=f//Frec
f=f-f1
pow=14
gosub power
f1=f1+powrez
f=f/powrez
f=f+powrez
date=f1
gosub sendit
date=f
gosub sendit
if s9833=1 then
date=%0000000000000000
gosub sendit
date=%1100000000000000
gosub sendit
high PORTC.0
high PORTC.6
In MPlab the date variable(binary) 00000000, quartz 00101100 and the same for all my word declared variables
I hope my problem is clearer now.
Thank you again Dwayne for the replay.
