Help me out..
Results 1 to 5 of 5
Thread: Help me out..
    Apr 2006
    Default Help me out..
    I need a help from members,to help me show me how i can use at/ps2 keyboard to enter text or data to the eeprom memory of the pic16f877a ,the code is attached and it works very fine for led sign display i was using pc to enter the text,
    DEFINE OSC 10 ' Oscillator speed in MHz: 3(3.58) 4 8 10 12 16 20 25 32 33 40
    Include "modedefs.bas" ' Include serial modes
    @ DEVICE PIC16F877A,HS_OSC,WDT_OFF,PWRT_ON,LVP_OFF,BOD_OFF
    CMCON = 7
    ADCON1 = 7
    TRISB = 0 ' Setup PortB = outputs module selection data
    TRISD = 0 ' Setup PortD = outputs the data word and address of module
    TRISA.2 = 0 : TRISA.1 = 0 : TRISA.0 = 0
    databits var PORTA.2 ' clock signal for the character segment data IC
    addsbits var PORTA.1 ' clock signal for the char. segment address data IC
    modsbits var PORTA.0 ' clock signal for the module select IC
    Addss VAR BYTE[8] ' 8-byte address array
    Mods VAR BYTE[8] ' 8-byte address array
    Datas var byte[64]' array to keep the ever changing character segments
    loops con 2 ' number of frame loops, for flicker-free effect
    columns con 63 ' columns + 1 = number of columns on the display, starts from 0 to 63 = 64
    module con 8 ' number of modules and columns on modules 8 x 8, indicates when to go to next module and when to start from beginning of module
    EOM con "" ' Character used as "End of Message" marker
    SPA con $D ' Character used as "End of Message" marker
    character_segment VAR BYTE ' data word for LED matrix
    column_select VAR BYTE ' variable that keeps track if one module length was exceeded
    module_select VAR BYTE ' variable that keeps track of which module should be activated
    i VAR BYTE ' for loop pointer
    iTMP var byte ' points to the char. segment that will start out the new scroll
    char var byte ' points to the char. that will be seperated into segments for display
    charTMP var byte ' points to the char that will start out the new scroll
    ColumnAddress VAR BYTE ' pointer that indexes which column in module is to be addressed
    LoopDisplay var byte ' pointer that indexes how many times the screen has been looped
    char2disp var byte ' variable that gets the character to display
    NEWcharflag var byte ' indicates that new char. needs to be displayed on start of next refresh
    message var byte ' stores how many columns have been taken up by message, scrolling message will = 63, message shorter than the lenght of sigh <= 62.
    displayme var word ' pause between each lighting of LEDs, in microseconds
    ''''' S T O R E A D D R E S S S E Q U E N C E S IN A R R A Y S ''''''''
    FOR i = 0 TO 7
    ' LOOKUP i,[$01,$02,$04,$08,$10,$20,$40,$80],module_select 'used with NPN transistors
    LOOKUP i,[$FE,$FD,$FB,$F7,$EF,$DF,$BF,$7F],module_select 'used with MIC5801 ICs & DM74ALS574 ICs
    Mods[i] = module_select ' Load all 8 addresses into array
    LOOKUP i,[$10,$20,$40,$80,$01,$02,$04,$08],column_select
    Addss[i] = column_select ' Load all 8 addresses into array
    NEXT i
    ''''' S T O R E C H A R A C T E R S E G M E N T S I N A R R A Y ''''''
    start: ' very start of the whole loop, this point will reset all variabled, and will start on a clean start
    char = 0 : charTMP = 0 : i = 0 : iTMP = 0 : NEWcharflag = 0 : 'reset all necessary variables
    message = columns
    MoveDataByOneColumn: 'the data display stars here
    i = iTMP : char = charTMP 'set the character segment and character to start out the display with
    NEWcharflag = 0 'reset the flag which indicates to start out with new character when the display stars scrolling
    FOR ColumnAddress = 0 TO columns 'store max. no. of segments in the data array, which is 64
    READ char,char2disp 'read a character from the eeprom memory
    'check if the character from the eeprom memory is a lower/upper case char. or a number or a special char.
    'then grab its' segment data from the 4 lookup tables containing all character
    If (char2disp >= "A") and (char2disp <= "Z") then
    goto UPPERcase
    If (char2disp >= "a") and (char2disp <= "z") then
    goto LOWERcase
    goto OTHERcase
    'done checking the character format, and grabbing its' segment values
    donecharacterlookup: 'done looking up the character data
    IF character_segment = EOM THEN 'check to see if end of character
    character_segment = $FF 'yes, so replace it with a blank, so there is a blank after each character
    char = char + 1 'increment pointer to next character in message
    i = 0 'reset index pointer that points to which char. segment to display
    if (ColumnAddress = 0) then 'check to see if this is the first time we're looping, we do not want to do this 64 times!
    charTMP = charTMP + 1 'increment the character pointer to next character, the next time the screen displays
    iTMP = 0 'reset index pointer that points which char. segment to display, next time the screen displays
    NEWcharflag = 1 'set a flag which indicates that new character must be displayed next time the screen displays
    endif 'end if
    else 'no, not the end of character
    i = i + 1 'increment pointer to the next char. segment of the character displaying
    endif 'done checking character segments
    Datas[ColumnAddress] = character_segment 'store the segment in the character segment array
    NEXT ColumnAddress 'do this 64 times to fill up the whole character segment array
    if NEWcharflag = 0 then 'check to see if the 'new character' flag was set
    iTMP = iTMP + 1 'no, so increment the pointer to point to new char. segment of character, next time the screen displays
    endif 'done incrementing pointer of character segments
    goto startDISPLAY
    fillDISPLAY:
    iTMP = 0 : charTMP = 0 : NEWcharflag = 0 ': GOTO MoveDataByOneColumn
    message = ColumnAddress 'store the message lenght to calculate the refresh rate later on
    for i = ColumnAddress TO columns 'fill up the data array with blanks if message is shorter than the length of the SIGN
    Datas[i] = $FF 'if message is shorter then the lenght of the SIGN, fill up rest of the columns with blanks
    next i
    to read a PS2 keyboard, you need something like...
                    '   PS2 Keypad signal
            DEFINE  PS2_SCLK        PORTC
            DEFINE  PS2_SCLK_BIT        1
            DEFINE  PS2_SDATA       PORTC
            DEFINE  PS2_SDATA_BIT       0
            '       Variables definition
            KeyPS2      var BYTE                ' Store pressed key
        ' some code here
                    '       Keypad scan routine
    ReadPS2:        '
                    '       data is packed in a 11 Bit format
                    '           Start, 8 bit data(LSB first), 1 parity, 1 stop.
                    '       data is available on the falling edge of the clk
            gotsync=0                           ' No synch received
        ScanIt:
                CHK?RP  PS2_SCLK
                CALL    SkipPulse               ; Skip the start bit
                CLRF    _BitCounter             ; clear bit counter
        ReadLoop
                BTFSC   PS2_SCLK,PS2_SCLK_BIT   ; wait for clk falling edge
                GOTO    $-1                     ;
            @   MOVE?TB PS2_SDATA,PS2_SDATA_BIT,_SDATA
            KeyPS2.0[BitCounter]=SDATA          ; Save current bit value
                BTFSS   PS2_SCLK,PS2_SCLK_BIT   ; wait for clk falling edge
                GOTO    $-1                     ;
                INCF    _BitCounter,F           ; increment bit counter
                MOVLW   8                       ;
                XORWF   _BitCounter,W           ; check if = 8 (end)
                BTFSS   STATUS,Z                ;
                GOTO    ReadLoop                ; if not read again
                CALL    SkipPulse               ; skip parity
                CALL    SkipPulse               ; skip stop bit
                GOTO    GetOut                  ; get out of here to test the
                                                ;     actual result
        SkipPulse
                BTFSC   PS2_SCLK,PS2_SCLK_BIT   ; wait for falling edge
                GOTO    $-1                     ;
                BTFSS   PS2_SCLK,PS2_SCLK_BIT   ; wait for rising edge
                GOTO    $-1                     ;
                RETURN                          ; Bye bye!
        GetOut
    Then, you need to build a HUGE lookup table and + conditions to fit the PS2 ScanCode which is store in KeyPS2 variable.
    The above don't check the parity, don't check the validity of the Start bit... it's just a plain and starter version.... sorry if it's mostly in ASM..
    In PBP it should be something close to...
    ReadPS2:
            FOR COUNTERBIT=0 TO 10
                WaitFallingEdge: if sclk then waitfallingedge
                KEY.0[COUNTERBit]=SDATA
                WaitRisingEdge: if sclk=0 then waitrisingedge
                NEXT
            KEY=(KEY>>1)&$ff
    there's few other example here and there in the forum. Melanie also draw the whole PC ScanCode table.
    at least
    http://www.picbasic.co.uk/forum/show...ghlight=ps2%2A
    http://www.picbasic.co.uk/forum/show...ight=scan+code
    Apr 2006
    Default Thanks
    Thank you Steve, for your concern i will give it a try and get back to you, mostly to use ps2 keyboard is good for the moving sign display as it serves as stand alone with out pc,when you plug the key board you just hit any funtion key like f1 to enter data,f2 to delete,and f3 to store the data etc, that will be fine for me .
    Apr 2006
    Default hello
    hello steve ,
    i have try it without success.
    anymore idea.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Quote Originally Posted by Joann View Post
    hello steve ,
    anymore idea.
    Perhaps you could post a schematic of what you have done? This may help others in helping you since the suggested code you have been offered is to be known as working.
    Best Regards,
    Trent Jackson
