Compile using MCS
Results 1 to 8 of 8
    malc-c's Avatar
    malc-c Guest
    Just done a search for run.* on my PC too and nothing found !
    What programmer are you using, and which version of MPLAB have you got installed
    MCS creates the files during the compile process. Then deletes them when it's done.
    run.bat
    run.pif
    The files are created in the same folder as the project being compiled.
    I don't know why it wouldn't be able to find them, unless the folder's path is too long or has some non-standard characters in it.
    Smile
    Thanks guys for the replies -
    I'm going to remove and reinstall PBP - I've already reinstalled MCS
    Darrel- You know, that could just be it. I renamed project directories just before this happened. I'll change them back & let you guys know what happens
    regards
    Angus
    Default Problem solved
    A reportback, chaps.
    I moved the PBP source files from a folder on the desktop into the MCS directory, and everything compiles fine.
    Angus
    malc-c's Avatar
    malc-c Guest
    If you open MCS and then select VIEW then EDITOR OPTIONS there is an option at the bottom of the settings for the default folder which is normally C:\Program Files\Mecanique\MCS
    If you then click on the change button you can select any other location on your PC
  1. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 17:43
  2. Cant change target processor to compile
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 9th November 2009, 19:31
  3. ICD use with MCS Plus, PBPro & PicKit2??
    Last Post: - 1st October 2009, 00:06
  4. Compile and Program help using PICKit2
    Last Post: - 10th March 2009, 15:51
  5. Replies: 2
    Last Post: - 9th February 2006, 23:03
