Fuses Again
Results 1 to 16 of 16
Thread: Fuses Again
    Default update
    only getting overwriteing previous address error now is that ok
    also your first line did not give xt-osc which is all i really am trying to start with
    mpsam is working perfectly expect when i try fuses
    sorry, i misread your first post. Anyways, you'll need this one
    @ __CONFIG  _XT_OSC & _MCLRE_ON  &  _LVP_OFF & _WDT_OFF & _PWRTE_ON  & _BODEN_ON
    Question ty
    thanks that seems to work except for the overwrite error
    is that a problem??
    Default See post # 4 this thread
    Quote Originally Posted by jcleaver View Post
    is that a problem??
    Hi Jack,
    Look at post #4 in this thread. Mr E. explained what to do to eliminate the last error of which you speak. The compiler sees the config default settings in the INC file and then sees the config setting in your code, and guess what it does?
    It ignores the setting in your code and goes with the default. So just add a semicolon ahead of the two statements he showed you and the compiler will forevermore do what you tell it for this chip. You will have to edit each individual inc file as needed. So why is that statement even in there? Did you ever compile a program without setting the configs? Did it work? Yes it probably did if you used a 4mhz chrystal, because of the default configs.
    Feb 2003
    Default Is "FUSES" the right term ???
    Just a thought....
    ...now that we mostly work with Flash devices rather than OTP, shouldnt we be referring to "Configuration Circuit Breakers" rather than "Configuration Fuses" because we can reset them.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Default inc files
    joe thanks for the info i guess what you are saying is i need to find the
    inc file for this chip and rem out the config statement so it writes it according to my programs
    the problem, which i had earlier and never really found a answer is i am not sure where it is looking for these files as i have many inc files for this chip
    got installed with some programmers and mpsam so really dont know which file to use.
    if i try the first part besides getting the error of overwriteing it will not go out to the programmer
    also if i try to use the second part of posting #4 i get huge errrors see my later listing
    so basically niether statement works for me
    must be a simpler way
    thanks
    jack
    http://www.picbasic.co.uk/forum/show...75&postcount=5
    We talk about commenting the PBP default ones. THE .INC file is located in the PBP folder.
    Default Sometimes it's more who you know than what you know.
    Hi Jack,
    What I am really saying is despite my inability to spell crystal properly, follow mister_e's instructions and you will be right 99.9999999062 % of the time, He will never intentionaly lead you astray! Same with most all of the other " BIG GUNS" in this forum same applies to BIG 'UNS too . I wish he was an investment counselor !
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. old chestnut, 18f2550, fuses, osc's leds...
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 31st October 2009, 18:18
  3. 18F4620 Fuses configuration
    By Pimentel in forum mel PIC BASIC Pro
    Last Post: - 4th October 2008, 14:23
  4. 18F Config fuses
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 16:59
  5. configuration fuses
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 18th April 2005, 11:50
