PIC's ports individual bits manipulation - how to?
Results 1 to 39 of 39
    SWITZERLAND (french speaking)
    Default PIC's ports individual bits manipulation - how to?
    Hello,
    In one of my projects, I have to adress the first (LSB) four bits of my PIC's PORTA.
    This is done within a FOR...NEXT loop so the bits are adressed as a variable ("Digit").
    I would like to use the other four bits for other purpose (Button, any Input...) but I can't make this the way I did it up to now.
    How is it possible to handle ONLY those four bits wihtout modifying the other (MSB) four bits?
    I've attached my code if you like to see how I've done it. Any comments/critics are very welcome.
    Roger
    Jan 2006
    Istanbul
    Hi flotulopex,
    Check this http://www.picbasic.co.uk/forum/showthread.php?t=3753
    May give you some ideas.
    Default yes, but...
    Thank you sayzer,
    I found this thread already. I tried Melanie's way but it doesn't work.
    First, it looks as "Digit" won't increment from 0 to 3.
    Second, I have put a "spy" before entering the loop. I put PORTA.6 = 1.
    Since I use PIC Simulator, I can see the port status and as soon as the program has started, PORTA.6 goes back to 0 (!?).
    Am I doing something wrong?
    In my code's FOR...NEXT loop, I have put:
        for Digit = 0 to 3
            value_d = value dig digit
            lookup value_d, [$7E,$0C,$B6,$9E,$CC,$DA,$FA,$0E,$FE,$DE], Segments
            PORTA.0(Digit) = ~DCD Digit
            PORTB = Segments
        next
    Roger
        for Digit = 0 to 3
            PORTB = Segments
        next
    I'm not so sure that ~DCD Digit will work. I could be wrong. Maybe: ~ (DCD Digit) ?
    And I don't see an initial 'ENABLE' in the program itself...not sure if that's needed either or if interrupts are 'ENABLE'd by default.
    Ha...just found the answer to that last 'not sure'. Page 183 of the PBP manual states that interrupts are NOT enabled by default...so, you have to turn them on.
    as you write to a BIT, it have to be 0 or 1 ONLY.
    Use a LCD or a serial comm to see the results of ~DCD digit... it return 254, 253, 251, 247.
    i bet PORTA.0[Digit]=1 is what you're looking for.
    May 2006
    Del Rio, TX, USA
    How about something simple, like:
    PORTA.0 = Digit.0
    PORTA.1 = Digit.1
    PORTA.2 = Digit.2
    PORTA.3 = Digit.3
    HTH,
    SteveB
    Default Testing...
    I just made this piece of code as test.
    MYPORT  var PORTA
    Loop    var BYTE
    PORTA.0 = MYport.0
    PORTA.1 = MYport.1
    PORTA.2 = MYport.2
    PORTA.3 = MYport.3
    PORTA.6 = 1 'Test to check port's state change in simulator...
    Start:
        for LOOP = 0 to 3
            myport.0[Loop] = 1  'High
            myport.0[loop] = 0  'Low
        next
        goto start
    It works except the PORTA.6 will change it's status from 1 to 0 when the firt loop will be executed.
    Roger
    I think you've got the variable declarations backwards.
    Try myport.0 = porta.0, etc. instead of the way you have it.
    this won't work indeed... and you make it too complicated for what it need to be.
    Start:
        for LOOP = 0 to 3
            PORTA.0[Loop] = 1  'High
            PAUSE 500
            PORTA.0[loop] = 0  'Low
        next
        goto start
    MyPORT.0=PORTA.0 will work only once, If you want to alias a variable bit to a PORT bit... it's an all different story..
    Default must be tricky
    I've attached two pictures about what I can see.
    The first picture "Before Loop Start" shows that my PORTA.0 to 3 are set to "1". This is because I need them to be at this state before the main loop starts (driving CA Leds).
    I did the same for PORTA.6 (=1) just for testing purpose. PORTA.6 will be used for something else in my program if I can handle the actual problem.
    When I start the execution of the program, PORTA.6 goes to "0" witch is unwanted here.
    Mister_E you're right, using DCD will modify all ports.... Was not a good idea on my side. Thank you for making me aware.
    Roger
    I should have see it first... You must set the TRIS register, unless those pin are set as input.
    MYPORT  var PORTB
    Loop    var BYTE
    TRISB=0
    PORTB.6 = 1 'Test to check port's state change in simulator...
    Start:
        for LOOP = 0 to 3
            PAUSE 500
        next
        goto start
    Looks like it might be a bug in the simulator. PortA.6 on the F88 is also OSC2/CLKO. I may have missed something, ya never know. Try it on the real thing and see what happens.
    Never mind.. misread the original code...
    Default I have to do it in "real"...
    You may be right!
    I just noticed that, using an additional microcontroler view in the simulator, the port doesn't change.
    So I'm going to make it in "real".
    Another thing; I have declared PORTA.6 as an Input (TRISA = %11110000). When I change this to an Output (TRISA = %10110000), the port will keep it's status as it should be.
    Unfortunalety, I will need it as an Input.
    I'll go back to my breadboard....
    Roger
    You may be right!
    Actually, I believe I heard both mister_e and DT both say that they don't trust simulators one bit.
    However, I trust the Microchip simulator almost implicitly. Why don't you try running your code on that and keeping an eye on the port values?
    Default Simulator...
    Well, the simulator I use is wrong. I checked with my logic probe, and this one says true.
    Skimask, I have tried to use the MELABS simulator if this is the one you're talking about.
    But, compared to the one I use, it was such a hassle to make it work that I abandonned this one.
    Is it the one you use?
    Roger
    flotulopex,
    INPUTDATA = PORTA >> 4 'LOWER 4 BITS OF INPUTDATA ARE NOW UPPER 4 BITS OR PORTA (INPUT PINS)
    PORTA = PORTA & %11110000 'STRIP LOWER 4 BITS OF PORTA
    PORTA = PORTA | (DIGIT & %00001111) 'REPLACE LOWER 4 BITS WITH NEW DIGIT DATA
    Now your upper 4 bits are stored in variable INPUTDATA. The lower 4 bits of PORTA have just been updated with the lower 4 bits of variable DIGIT.
    If I'm incorrect about your original question? I can't think of any easier method.
    Flotulopex,
    as far as i'm aware of MELABS don't do any Simulator... but i could be wrong.
    Skimask talked about the built-in MPLAB simulator (Debugger>Select Tool>>MPLAB Sim) one.
    To use it, you need to add some 'Watch' (View>Watch) and then you enjoy seeing them changing.
    Thanks Dave, this is another way to solve my problem.
    Indexing the port may be faster in the loop's execution (I need speed).
    Roger
    Right then Mister_e, that's the one I had a hard time to make work...
    Maybe I should insist a little more.
    The simulator I use is that easy... but maybe not fully reliable so it may be worth to spend more time on the MELABS Sim programmer.
    Roger
    I don't know if the MPLABs simulator is 'hard to use', at least I don't think so anyways. There is a bit of an initial learning curve to figure out which windows to use, which keystrokes and which functions key are really handy, etc.
    All I do it pull up MPSIM, load the .asm file that PBP gave me, and run it, or single step it or whatever. Yes, you need to have some input values, and maybe a stimulus file, but I don't use any of that and just set my program up to 'fake' those values.
    All I can say is that MPSIM has always treated me right...and I especially like the 'stopwatch' function.
    Well it's actually pretty simple once you know how.
    Start a new project using the usual method, then Select MPLAB Sim and compile your code.
    Go to View> Watch, right to Add Symbol chose the variable you want to monitor and add them in the list.
    If you want to monitor a PORT ouput, you go on the Add SFR side.
    Once done, press f9 and enjoy the show.
    If you have some PAUSE, PAUSEUS in your code... comment them.
    You can use and create your Code in MPLAB and use the animate mode... it works. You just need to install properly the MPLAB plug-in. Easier to figure out than the .ASM file.
    Today i notice that Microchip have added the VSM plug-in. I need to laugh and waste some time... i'll try it...
    Ça, c'est la phrase qui tue :-)
    I wish this could be as simple as it looks like... to your (expert) eyes.
    Going to sleep now but tomorrow, MELABS will have to be nice with me!
    Bonne nuit.
    Roger
    MELABS or MPLAB?
    Bonne nuit
    Update to the VSM... painful and useless as you can't create your OWN neither modify the provided sample...
    Idiot and useless...
    May 2006
    Del Rio, TX, USA
    I might have misread the original intent, but you did ask:
    "Under the hood" PBP will either write to the port as a Byte, or set/clear individual bits. This means you have 2 basic approaches:
    1) Dave's approach, which deals with the port as a byte. This uses some bit manipulation to preserve the status of the MSBs.
    2) And what I was trying to get at, but was not very clear, and that is to set each bit individually.
    Just so I've got it straight, as your FOR...NEXT loop counts from 0 to 3 you would like to see a pattern on PORTAs LSB like: 0001, 0010, 0100, 1000. Is this correct?
    If this is the case, then this should work:
    Digit VAR Byte
    DCD_temp VAR Byte
    FOR Digit = 0 TO 3
         DCD_temp = DCD Digit
         PORTA.0 = DCD_temp.0
         PORTA.1 = DCD_temp.1
         PORTA.2 = DCD_temp.2
         PORTA.3 = DCD_temp.3
    NEXT Digit
    SteveB
    nish's Avatar
    nish Guest
    Default Timer1 in pic16f877a
    hi all
    i m new to pic16f877a.i need a help regarding timers in pic 16f877a.
    in the timer1,T1CON register what is the purpose of using T1OSCEN bit and the T1SYNC bit.if we are using T1SYNC bit,with what signal it will get synchronised and the purpose of synchronization.expecting the reply.
    thanx n advance
    nish
    Default MPLAB, of course...
    I was already sleeping when I wrote this big mistake.
    Thanks SteveB; indexing the ports, like "PORTA.0[Var]", works well. But you're right, it is about to adress the four LSBs.
    Roger
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    If the upper four bytes are guaranteed to always be inputs then you do not need to worry about how “they” are affected by your modifications of the lower four output bytes. Your
    PORTA = ~DCD digit
    should work fine (all reads are of the actual values of the pins irrespective of any previous written values; all writes are read-modify-write operations).
    If the upper four bits could be outputs then you do need to worry and you can use one of the suggested fixes. If speed is an issue as you suggest (but I do not see why it would be, especially with a pause in the main loop), then you could 1) switch to real interrupts (see Darrel's methods) and 2) unroll your for-next loop. A possible version is shown below for the latter.
    ' PORTA = XXXX1111
    value_d = value dig 3    'Select the 3 Digit Value
    PORTA = PORTA - 8 ' PORTA = XXXX0111
    PORTB = Segments
    pause Scan
    MAIN:
    value_d = value dig 0    'Select the 0 Digit Value
    PORTA = PORTA +7 ' PORTA = XXXX1110
    PORTB = Segments
    pause Scan
    value_d = value dig 1    'Select the 1 Digit Value
    PORTA = PORTA - 1  ' PORTA = XXXX1101
    PORTB = Segments
    pause Scan
    value_d = value dig 2    'Select the 2 Digit Value
    PORTA = PORTA - 2  ' PORTA = XXXX1011
    PORTB = Segments
    pause Scan
    PORTA = PORTA - 4 ' PORTA = XXXX0111
    PORTB = Segments
    pause Scan
    Goto MAIN
    and for clarity – any change to a single pin in PBP actually is writing to the entire port. (i.e, if you do this PORTA.0=1 then the microprocessor does this PORTA = uuuuuuu1 where the u is the value of the port pin at the time of the execution of the command)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Thanks a lot, Paul.
    First, the "need for speed" is due to the display refresh rate. The higher the speed is, the less time each digit is going to be light on and so, it will dimm naturally.
    If I want to make the display brighter, I slow down the loop with the "Scan" pause making the digit to be powered longer.
    I could do it another way with a slower clock rate: dimm the LEDs with transistors (this is what I actually did).
    Another way would also be to modulate the voltage for each digit's pin at the µc. But I'm not so far yet
    PORTA = ~DCD Digit will set 1 bit to a state and all others to the other state; this is an unwanted effect in my case.
    I didn't think about your solution; it's always amazing to see how many different ways there are to solve a problem. I will try it anyway since I want to know witch is more memory space effective.
    Roger
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by paul borgmeier View Post
    Paul, looking at the ASM, bitwise manipulation of the port is handled by BSF/BCF commands. For example.
    PORTA.3 = 1 results in: BSF PORTA, 003h
    PORTA.2 = 0 results in: BCF PORTA, 002h
    and
    PORTA.1 = DCD_temp.1 results in:
         btfsc   _DCD_temp, 001h
         bsf     PORTA,  001h
         btfss   _DCD_temp, 001h
         bcf     PORTA,  001h
    Are you saying that even these bitwise commands, when actually implemented by the PIC, will write to the whole port?
    Feb 2003
    Smile
    Quote Originally Posted by SteveB View Post
    Yes - the entire port is updated via port R-M-W when using bcf or bsf.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Feb 2003
    Smile
    Have you demonstrated this? Your loop has each digit on for about ¼ the time. Frequency should be irrelevant because with higher frequceny, it will be lit less but will be lit more often. Would not you need to turn the digit off before the pause (or between pauses) to affect the dimness? I will have to think about it more.
    I thought you wanted
    MAIN:
    PORTA = XXXX1110
    PORTA = XXXX1101
    PORTA = XXXX1011
    PORTA = XXXX0111
    GOTO MAIN
    where the upper nibble were inputs? If they are inputs, they will not be affected by your PORTA=~DCD command because, well, they are inputs.
    Earlier you mentioned speed is an issue, now you mention code space – the unrolled version will not be very code efficient but it should by slightly faster than the looped depending on How PBP converts them to ASM. If one were to write it in ASM, I know the unrolled method would be faster (at least I know I could write an ASM version faster than a looped. Also the PORTA add commands could be done in two instructions versus more as with the >>, & and | approach). However, I still do not know if your upper nibble of PORTA will always be inputs?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    flotulopex,The statement: "If I want to make the display brighter, I slow down the loop with the "Scan" pause making the digit to be powered longer." makes no sense if the drive circuitry is designed correctly and the software is truly multiplexing the digit drivers at 100%/number of displays. The only thing that lowering the display frequency will do is at the lower end of about 50 to 40 hz the viewer will start to see the telltale multiplexing action. If at 60 hz. or more the display brightness should not change as far as your eye is concerned. If your display gets brighter as you increase the frequency then your circuitry is not shutting off the digits fast enough. If it gets dimmer as you increase the frequency then your circuitry is not turning on fast enough. This is assuming you have the dutycycle set at 100%/number of displays with no delays. I have designed an automotive gage set using a 16f88 that runs a 4 digit + decimal point multiplexed display that has a 16 step dimming function thru an A/D channel tied to the dashboard dimmer. I chose 63 hz as the lowest frequency to eliminate the STROBING effect during driving.
    Default answers...
    Paul,
    The four higher bits of PORTA are Inputs and when I checked out the levels on my PIC with my logic probe (set to TTL), using ~DCD would make the ports change status. BUT I have to try with another my PIC since one of my digits doesn't light-up normally making me think about a "little" problem... Should get a new one tomorrow.
    About dimming, modifying the scan (refresh) rate of the digits is effectively not a good solution. It's working but, as said in another post, the strobe effect is also accentuated. I have modified my circuit and added transistors in each Common Anode connection. Those four transistors are then levelled by one additional transistor witch is LDR driven. At least, it works fine.
    Dave,
    My approach is maybe not a good one and any example/critic/suggestion is welcome. It's my first project involving a LED display, I didn't even know what multiplexing was before, so got still to learn more... My english is poor, what is a "gage set"?
    Roger
    flotulopex, It is a set of digital gages used for automobiles. About 3 years ago I gutted a trio of small SUN aftermarket gages in chrome cans and built digital inerds for each. 1 displays water temperature, 1 oil pressure, and 1 battery voltage/current. I beleive the MELABS web site has an intorduction to display multiplexing that you should see and i beleive also some code that you can use as a basis for your program if this helps.
    Feb 2003
    Smile
    When using digital inputs, you need to make sure the external connection are either high or low. It sounds like what you are testing are floating (unconnected) inputs, which is a big no-no (not the testing of, but leaving inputs unconnected). Tie your inputs either high or low and repeat - you will see that they are not affected by your DCD command.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Default pull-ups, pull-ups....
    This could be the trick.
    Let me check over and I'll come back.
    Roger
    Default DCD works fine... and faster
    Yes Paul, you're absolutely right.
    The DCD command doesn't affect the input ports. Personally, I would appreciate to see this kind of information in the PBP manual. Maybe it will be there in the next edition?
    As you mentionned, it is not a good idea to measure ports whithout pull-ups or pull-downs; what I did now.
    So, DCD works fine and faster than indexing the ports.
    Thank you very much.
    Roger
    Last Post: - 14th June 2016, 08:55
  2. Individual Variable bits
    By tazntex in forum General
    Last Post: - 31st January 2008, 19:27
  3. Equating Ports to Data Bits
    By Osiris in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2006, 16:00
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
  5. pics with 3 hardware PWM ports
    By CBUK in forum mel PIC BASIC Pro
    Last Post: - 5th August 2004, 01:14
