Fuses Again
Results 1 to 16 of 16
Thread: Fuses Again
    Exclamation Fuses Again
    as it seems i have to go beyond pbp to get certain programs to work
    damm fuses again
    i am trying something very simple to start the training
    chip 16f627a
    assembler mpasm
    trying to set chip for external osc because most people say this is required to run serial communications
    tried the following statements
    @ device xt_osc
    @device pic16f627a,xt_osc
    @_config_xt_osc
    _config_xt_osc
    all commands generate error messages in a simple 4 line program which assembles fine without the commands
    wish pbp would include these setups as part of the compileing
    Thumbs up
    Have a look to the following. Everything should be covered.
    Presetting Configuration Fuses (PIC Defines) into your Program
    Cool link
    mister e
    thats where i went to get started seemed simple enough
    however all the commands shown see above
    generate a error
    errors or warning.. that's the question!
    tell me
    1. the error number your program return e.g. Error[118]c:\... Overwriting previous address content (2007)
    2. MPASM version
    3. PBP version
    4. your config line
    5. the modified .INC file in your PBP folder.
    Here, PBP 2.47, MPASM 5.06
            @ __CONFIG  _INTRC_OSC_NOCLKOUT & _MCLRE_ON  &  _LVP_OFF & _WDT_OFF & _PWRTE_ON  & _BODEN_ON
    and the 16F627A.INC file
    ;*  16F627A.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2003 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 11/06/03                                        *
    ;*  Version   : 2.45                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            include 'M16F62xA.INC'  ; PM header
            ;device  pic16F627A, xt_osc, wdt_on, mclr_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F627A, r = dec, w = -302
            INCLUDE "P16F627A.INC"  ; MPASM  Header
            ;__config _XT_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
            NOLIST
            LIST
    pbp 2.46 mpsam 5.
    errors 113 and 118 are listed when i try the first line above
    this is warning with the second part above
    WARNING: Unable to open INCLUDE file P16F627A.INC.
    ERROR Line 25: Syntax error. (mistre.pbp)
    ERROR Line 26: Bad parameter to LIST command. (mistre.pbp)
    ERROR Line 27: Syntax error. (mistre.pbp)
    ERROR Line 31: ELSE without a matching IF..THEN. (mistre.pbp)
    ERROR Line 32: Bad parameter to LIST command. (mistre.pbp)
    ERROR Line 33: Bad parameter to LIST command. (mistre.pbp)
    ERROR Line 37: ENDIF without a matching IF..THEN. (mistre.pbp)
    ERROR Line 38: Bad parameter to LIST command. (mistre.pbp)
    post your whole code... and make sure your MPASM PATH is right and MPASM is checked in the Compile and Program Option> assembler tab of MicroCode Studio.
    Quote Originally Posted by jcleaver View Post
    damm fuses again
    chip 16f627a
    assembler mpasm
    @ device xt_osc
    @_config_xt_osc
    _config_xt_osc
    Computers are stupid, PICs are stupid, they are not however, sloppy. So when they want some piece of code they will not accept a peace of kode, because they are stupid.
    Now look at mister_e's code, the word config is preceded by __ not _ , that's two little Hyphen slash thingies, not one.
    I hope this helps.
    JS
    Default update
    might want to take a look at mikroelekronika there assembler and programer
    make duck soup out of working with fuses just check off like a list
    looks very simple
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. old chestnut, 18f2550, fuses, osc's leds...
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 31st October 2009, 17:18
  3. 18F4620 Fuses configuration
    By Pimentel in forum mel PIC BASIC Pro
    Last Post: - 4th October 2008, 13:23
  4. 18F Config fuses
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 15:59
  5. configuration fuses
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 18th April 2005, 10:50
