turning gpio.0 high after pwm command
Results 1 to 8 of 8
    Jan 2007
    Brazil
    Default turning gpio.0 high after pwm command
    i've just developed a dimmer for the internal light of the car using pic12f629 but i've a problem:
    when gpio.1 goes low, gpio.0 goes high (turning the lamp on) (gpio.0 = 1)
    just after that, when gpio.1 goes high, gpio.0 goes low with PWM. (pwm gpio.0,duty,cycle)
    at the first execution, it works fine. But if gpio.1 goes low again, gpio.0 DOESNT go high and when gpio.1 goes high, the PWM works...
    the code is attached.
    thanks, Sylvio
    I remember of few strange behaviour with this specific PWM. As far as i remind, it trick the TRIS setting and sometimes it set the i/o to input at the end.
    Try to use LOW and HIGH after PWM instead of using Io=1 or Io=0
    Hi Sylvio. I had a similar problem with the 16F819. It turns out that before I could reuse that port as an output, I had to disable the PWM with
    CCP1CON = 0 'TURN OFF PWM
    Maybe this will help.
    i wasn't aware that a 12F629 had a CCP module
    Jan 2007
    Brazil
    Smile
    he.. peterdeco.. mister e is correct, pic12f629 has no CCP module..
    thanks for the suggestion.
    i'm using soft pwm ..
    mister e, i have changed everything to HIGH and LOW and it worked really fine!
    thanks a lot...!
    Sylvio
    Bah don't blame Peterdeco, it's usual to everyone to mix PWM, HPWM and miss something in a post.
    Glad to know it's working. At least my memory was good this time
    Enjoy!
    Thanks Steve. I don't have these devices memorized. I saw PWM and it reminded me of my 16F819 problem a year or 2 ago.
    Bah, no problem Peterdeco1, even a superhero may fail... even me
    You where right, with a CCP module your solution will work. The only thing i would add for safety sake is a LOW pin after.
    But i'm an old guy using old method... LMAO!
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. need help simulating PS/2 mouse
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 9th December 2007, 22:49
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  5. Strangw results when using PWM command
    Last Post: - 10th July 2006, 13:14
