Elnec Programmer
Results 1 to 21 of 21
    mmm, i don't have the PikProg+ but the relabeled of Smartprog (BK844A). And i don't have any problem with...
    Certainly Elnec have the answer or tips...
    I NEVER do the ID check so far.
    In Windows device manager, you could still try to play with the LPT1 proprieties. about those interrupts.. maybe
    If you heard something from Elnec, please forward it here.
    Hi Steve. Thanks for the reply. Be sure that first thing was to contact ELNEC. They say it is the first time to hear a problem like that.
    I have copied the settings from the old PC. They are exactly the same like copy/paste. Unfortunately it is not reliable, does not program the chips although running the selftest and selftest plus does not show anything... :-((
    Sure I will let you know how it goes. Now I am trying to install a PCI Epress card with 2 rs232 and 1 parallel port. When/if I manage to instal it (damn asians....) I will try the programmer.
    INDEEED That was my next suggestion... i think it might solve some part of the problem.
    Some on-board stuff are sometime painful... it's worst every year...
    OK, board installed OK and checked with a printer. Now running the programmer software, is unable to see the programmer. I set LPT to LPT1 for the new parallel port, but SW does not find it. Tried also to give direct address, which now is in the range of CCD0 to CCFF, rather high relative to the on-board LPT port....
    Oh, what a nightmare..
    mmm... usually when you install the PG4Uxx software it also install a driver. Try removing the software and re-install the latest version. the you should be prompted to reboot your system.
    i agree.. what a pain.
    Can you disable the on-board LPT port in your BIOS?
    Yes I did it. First thing. So there is no conflict between the two ports. I am concerned about the address of the new port. It is too high. May be that's why PG4U does not see the port...
    I 'll try to reinstall the sw and see what happens...
    Thanks Steve.
    if the driver don't allow you to move it to the usual LPTx address or use dedicated LPT name (in Port Settings), i don't know what could happen.
  1. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 03:11
  2. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 21:14
  3. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 16th August 2006, 00:47
  4. Melabs USB Programmer
    By tmurph in forum General
    Last Post: - 25th December 2005, 04:25
  5. General Programmer Questions
    By mslaney in forum General
    Last Post: - 17th December 2004, 19:16
