Reading eeprom
Results 1 to 2 of 2
Thread: Reading eeprom
    Sep 2005
    Switzerland
    Default Reading eeprom
    Hi everybody,
    I've done a simple project pic + 24c16 + dallas 1wire temperature sensor.
    Every hour the temperature is saved into the 24c16.
    At the moment I remove the eeprom and I read the temp. with a eeprom reader
    prg.
    All this was ok for testing by now I'd like to be able to read it without removing it every time. I thought I could add a max232 and get the datas through the serial.
    I could add some lines in the pic prg., read the eeprom and display the datas in hyperterm and then save it.
    I would prefer, if possible, without a involving the pic.
    Do you have some good (easy) idea how I could do it ?
    Thanks in advance
    Bye
    Lotondo
    Yes you have it.. just send the whole data to Hyperterm, save the file as a .BIN and open/edit it in your Hex editor.
    OR, use comma and open it in EXCEL..
    it's all depend on how your EEPROM structure is made.
    Another point of view, format everything on the PIC side in a kind of TEXT report, then dump it to your PC.
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Writing & Reading to iButton EEPROM
    By crhomberg in forum Code Examples
    Last Post: - 6th October 2008, 20:40
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    By TONIGALEA in forum mel PIC BASIC Pro
    Last Post: - 6th July 2004, 20:59
