Low-Cost USB Oscilloscope
Results 1 to 40 of 41
Threaded View
  1. #36
    Bombay, India
    BitScope manages to pull off measuring one shot events @ 20MHz with only 40M samples. See; http://www.bitscope.com/design/
    So, I guess this is ultimately my question; how do they do it? How in the world can a complex waveform be captured at 20MHz with only 40M samples?
    What they are trying to state is the Nyquist criterion; where a frequency can be represented by at least 2 points on the wave. So, 40 mega samples can actually capture a frequency of 20MHz max; with a caveat - the frequencies must be in sync or you will see aliasing. And no matter what, you cannot *fill in the gaps* if you have only 2 samples in one cycle.
    I would reckon that the bitscope could capture with reasonable faithfulness an aperiodic wave @40Ms/sec uptil about 40/8 = 5MHz. Obviously, it will be better to have more samples to fill the gaps; thats where the sub-sampling term comes in - this is suitable only for periodic waveforms. The nearest possibility without sub-sampling is B-spline interpolation for single shot data.
  1. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  2. Pic16f84 and RC5 kode
    By terminator in forum Bluetooth
    Last Post: - 18th June 2007, 22:40
  3. Microcontroller with 2 way paging application problem
  4. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 18:19
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 04:14
