Newbie radio link issue
Results 1 to 32 of 32
    New Zealand
    You don't think SEROUT2 running 20MHz could send enough data to change the default setting in the radio module? Is my syntax correct in how I'd send it? If you think that the serout won't do 19200 then I think I'll just cut my losses and try find another module that just works, the manufacturer did say that I could send it back and they would change it in the factory and send it back to me - however they r on the opposite side of the planet!
    Try with DEBUG first. it's probably better. BUT both of them worth a try for sure.
    New Zealand
    sweet - will try with debug - is my syntax correct?
    SEROUT pin,baud,["ER_CMD#U1"]
    sorry - i mean:
    DEBUG "ER_CMD#U1"
    should be good. Don't forget to set the according DEFINEs listed in the manual.
    Good luck!
    Quote Originally Posted by George View Post
    If you've got a few extra crystals handy (and assume that you just happen to have the right values ), how about tell the compiler you're using 2400 baud with 4mhz, but actually use a 32mhz. The compiler won't know the difference and you'll be running at 19,200.
    But since you're running a 16F series, you're probably limited to 20mhz (depending), so maybe, tell the compiler you're running 4mhz with 9600 baud, and actually use 8mhz, to which you'll get 19,200 baud...
    But there I go thinking again...gotta stop that...
    yes, tricking the way you said should work... but i don't see any advantage here.
    According to the manual, when using SERIN/SEROUT, 4mhz only get you 2400 baud reliably. Tricking the compiler, a person should be able to get 4800 on 8mhz, 9600 on 16mhz, etc. without too much worry...that's all.
    I'm using this sort of thing to work my comm's at 38,400 with a bit more accuracy (I think). My program, running at 40mhz, didn't seem to want to run when compiled with DEFINE OSC 40 and SEROUT2...6 to get 38,400 comm's. But, if I defined 4mhz and SEROUT2...254, and just pretended to be using 3,840bps, it worked like a champ. I dunno, maybe the timing was just off that one or two extra microseconds or something...
    New Zealand
    How do I know if I transmit the data inverted or true? What's most likely? Cheers
    Probe your serial PIN at the end of the transmission. If this pin is HIGH, you're in the TRUE mode, unless you're in INVERTED mode.
    New Zealand
    Have ordered a couple of linx TXM-418-LR modules - hopefully they will work better for my application - anyone had success with these? They actually look like really good bit's of kit, cheap, small and overpowered! The only downside to prototyping with them is they r SMD.
  1. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 19:41
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  3. Replies: 5
    Last Post: - 6th September 2007, 04:59
  4. quickBlue™ Link
    By lester in forum Bluetooth
    Last Post: - 20th March 2007, 13:23
  5. 18F1320 ... Strange Memory
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th April 2006, 09:55
