Newbie radio link issue
Results 1 to 32 of 32
    New Zealand
    What's the command line to make it just send the AAh bytes repeatedly? As I said before I'm totally new to serial comms - are you meaning simply as:
    SEROUT PortA.0,0,["AAh"]?
    Does anyone have any recommendations as to a good radio set to use - like one where you hook it up and it works? No internal settings that are adjustable etc - just goes
    AAh : AA is the value, h represent Hexadecimal.
    SEROUT pin, baud, [$AA,$AA,$AA,$AA,$AA, YouDataVariable]
    OR
    SEROUT2 pin,baud,[REP $AA\5,YourDataVariable]
    Anything from Linx, Laipac, RFSolution, Maxstream will work without too much adjustment, but the manchester protocol have to be use in most case.
    Sometimes just by sending some $AA, a header, your variables may work good. If you don't have many data to sent, i don't think Manchester is really needed.
    Transmitter
    SEROUT2 ...[REP $AA\5,"READY", YourVariable]
    Receiver
    SERIN2 ...[WAIT("READY),YourVariable]
    Just for testing try to send repeatedly:
    loop:
    SEROUT pin, baud, [$AA]
    goto loop
    This will send endless AA to the receiver.
    If you read them then you need to encode your data.
    If you don't then you need to check the design back from zero.
    For modules contact me private if you need many. We build our own.
    New Zealand
    Have found the problem, wrote to the manufacturer and they replied with this:
    The ER modules are pre-set to 19200 baud. If you cannot talk to them at this speed then you cannot use them. One of the best ways to get around this is to purchase the eval kit for 55 pounds. This has two pcb boards, leads, antennas etc. which enable you to connect the module to a PC that can communicate at 19200 baud. Then you can send the ER command to change the board rate to PIC baud rate you need for example 2400 etc.
    So I was thinking about building another board with a 20MHz crystal and try send it the commands to change down to 2400. If I do this - am not really sure of the syntax - it says in the datasheet the comm settings is ER_CMD#U1 so do I send it like this SEROUT pin,baud,["ER_CMD#U1"] ???
    Thanks again for all your guys input so far
    any link to the datasheet?
    New Zealand
    O.K. i heard you but any link to the datasheet?
    New Zealand
    Sorry - here it is: http://www.lprs.co.uk/pdf_directory/....3-sept-05.pdf
    BTW - if I make a 20MHz board - what size caps do I use with my crystal? I use to use 22pF with 4MHz - does that mean I use 5pF with 20MHz?
    cheers
    the recommended cap are listed in your datasheet. usually 22pF is a nice choice.
    In theory your SEROUT is good. BUT, to me, you still have to transmit it with the default baudrate.. so it doesn't solve the problem unless you buy the suggested module to reprogram them first.. waste of time and money to me.
    BTW @19200 baud, for ANY reliable serial comm, i'll suggest you to use the PIC USART with HSERIN/HSEROUT instead.
  1. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 20:41
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. Replies: 5
    Last Post: - 6th September 2007, 05:59
  4. quickBlue™ Link
    By lester in forum Bluetooth
    Last Post: - 20th March 2007, 14:23
  5. 18F1320 ... Strange Memory
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th April 2006, 10:55
