SMPS - Switching Mode Power Supplies - Any example ?
Results 1 to 11 of 11
    SWITZERLAND (french speaking)
    Default some links for me please?
    Hello Mister_E,
    Would you have one or more links to these components please? I must not search the right way (correct words) since I can't find anything.
    By the way, what do you use (what would you use) in this case?
    Thank you HenrikOlsson, I read this application note already. Unfortunately, this kind of power supply allows only extremeley narrow min/max power ranges.
    Roger
    How much current do you need?
    Default around.... 0,05mA
    I need around 0,05mA.
    Input voltage is 230VAC 50Hz (Europe).
    Roger
    eeuuuhh 0.05 mA or 0.05 A
    Default My english is really bad.... :-)
    ... had a translation problem.
    It is 0,05A or 50mA.
    Roger
    same thing to me, but it make much sense...
    for ONLY 50mA, i don't think it really worth to build something really complicated and over price the whole thing. Maybe the Melanie's Transformerless Power Supply example could be enough with few mods.
    mine too, but... who cares
    EDIT: maybe something around those one
    http://www.discovercircuits.com/DJ-C.../offline5v.htm
    http://www.st.com/stonline/products/...re/an/8313.pdf
    be really careful with that kind of stuff..
    Feb 2003
    EEEEKKKK!!!!!!
    OK, so it does say that the circuit is NON ISOLATED and DANGEROUS VOLTAGES EXIST EVERYWHERE but I would suggest that by having the dropper resistor in the neutral leg rather than the HOT leg, it is making it more dangerous than it need be.
    If the resistor fails then the circuit stops working but EVERYTHING WILL STILL BE LIVE whereas if the resistor was in the live leg and failed then it would still stop working but the majority of the circuit would only be connected to neutral. Still wouldnt want to touch any part of it though!
    Obviously using a 2 pin mains connector would mean that there is no guarantee of polarity anyway so the above point would be irrelevant.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. High Power Consumption in Sleep Mode
    Last Post: - 18th September 2014, 13:29
  2. Replies: 4
    Last Post: - 9th October 2009, 08:01
  3. Switch mode power supply Pic Micro
    Last Post: - 29th July 2009, 13:11
  4. switch mode power supply with PWM
    Last Post: - 14th July 2009, 20:51
  5. Replies: 24
    Last Post: - 22nd December 2007, 06:46
