SMPS - Switching Mode Power Supplies - Any example ?
Results 1 to 11 of 11
    depending your current requirement, you may find some already built one fore few bucks. i don't think they even need to be design in most case.
    Most company have some SMPS controller IC as well. worth to have a look there.
    SWITZERLAND (french speaking)
    Default some links for me please?
    Hello Mister_E,
    Would you have one or more links to these components please? I must not search the right way (correct words) since I can't find anything.
    By the way, what do you use (what would you use) in this case?
    Thank you HenrikOlsson, I read this application note already. Unfortunately, this kind of power supply allows only extremeley narrow min/max power ranges.
    Roger
    How much current do you need?
    Default around.... 0,05mA
    I need around 0,05mA.
    Input voltage is 230VAC 50Hz (Europe).
    Roger
    eeuuuhh 0.05 mA or 0.05 A
    Default My english is really bad.... :-)
    ... had a translation problem.
    It is 0,05A or 50mA.
    Roger
    same thing to me, but it make much sense...
    for ONLY 50mA, i don't think it really worth to build something really complicated and over price the whole thing. Maybe the Melanie's Transformerless Power Supply example could be enough with few mods.
    mine too, but... who cares
    EDIT: maybe something around those one
    http://www.discovercircuits.com/DJ-C.../offline5v.htm
    http://www.st.com/stonline/products/...re/an/8313.pdf
    be really careful with that kind of stuff..
  1. High Power Consumption in Sleep Mode
    Last Post: - 18th September 2014, 14:29
  2. Replies: 4
    Last Post: - 9th October 2009, 09:01
  3. Switch mode power supply Pic Micro
    Last Post: - 29th July 2009, 14:11
  4. switch mode power supply with PWM
    Last Post: - 14th July 2009, 21:51
  5. Replies: 24
    Last Post: - 22nd December 2007, 07:46
