That would lead me to believe that your power supply's output impedance is too high, voltage dropping out if only for a couple of milliseconds, something you'd probably miss even on a 'scope. Starting current for most motors is quite a bit higher than running current, even under load. Maybe try seperating the PIC's power supply from the motor's supply?
