Multiple PIC's with 1 crystal
Results 1 to 12 of 12
    puma's Avatar
    puma Guest
    Thanks melanie for the explanation. It help me verry much. If have some projects in my mind where I could use this knowhow. For example:
    If have a master PIC wich sends datastream to several slave PIC's (8 or so) they filter and use the data to do something with it. When they share/use the same oscillator stream I could get the slave PIC's to do there task at exactly the same time (when al other slave PIC are ready to)
    Again thanks.
    New Hampshire
    Melanie,
    I would like to share the crystal of a 16f876 with a 12f675. By your description, I tie osc2 from the 876 to osc1 of the 675. What about osc2 of the 675. Do I leave it hanging or tie it to something?
    Thank you,
    Ross
    Never enough knowledge to be called intelligent but just enough knowledge to be considered dangerous!
    I like that! :-)
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 12:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 14:23
