Math problem
Results 1 to 8 of 8
Thread: Math problem
    Quote Originally Posted by selbstdual View Post
    I changed the code to
    	Second_First = Second_Value - First_Value
    	IF Second_First.15=1 THEN
    		Difference_First_Second = First - Second
            	Difference_Third_Second = Third - Second
    		Difference_First_Second = Second - First
            	Difference_Third_Second = Second - Third
    Result:
    			Is	Should
    First			1386	1386
    Second			771	771
    Third			882	882
    Point_One		449	449
    Point_Two		1663	1663
    Steps_First_Second	3	380
    Steps_Third_Second	14	68
    Calculation: Value stored by WRITE:
    Value1 Value2
    Byte0 Byte1
    Value(Like First, Second etc.) = Byte1*256 + Byte0
    And again, we've had this conversation before. You're overflowing the limits of your variables. For instance:
    x var word
    y var word
    z var word
    x = 1000
    y = 1000
    z = x * y
    You'd expect z to equal 1,000,000, but it work, because it's a word, 16 bits, a word and only a word, 16 bits, nothing more, nothing less. The answer in this case is not 1,000,000, but 16,960. You've either got to learn how to do 32 bit math (which is explained in the PBP manual and will work just fine), or cut down your input numbers a bit to keep them from overflowing the results.
    In a world of german electrons
    So you are talking about page 35. Lets see.
    Just take your test numbers and put them all below 255 and try the math. Assuming you've shown us all of your code and not just a small chunk, it should work.
    It does work.
    But this is a huge effort for dividing and multiplying.
    I want to have full 32-Bit or better 64-Bit calculation in the next version.
    It has to be mentioned that it is much easier than assembler also.
  1. Line Graph, math problem...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 04:20
  2. Math problem with string result
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 10:06
  3. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 04:36
  4. Math Formula / Variable Problem! Help!
    By bwarp in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 07:59
  5. Math problem...with picbasic pro
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 15th October 2005, 19:28
