PIC16F917 stack issues
Results 1 to 7 of 7
    Bombay, India
    Default PIC16F917 stack issues
    Hi
    I have programmed a 16F917 with PBP 2.46 It is an extensive application generating around 4058 words. I use assembly level interrupts to multiplex 8 seven segment displays. Besides this, I handle a dot matrix printer to print logs. I2C handles an external 24C512 and a PCF8583 RTC.
    There is a lot of code which nests upto 6 levels deep (if I dig into the listing file). Of this, the I2Cread and write itself nests to 3 levels deep. My code nests upto 3 levels deep. 1 level is for display refresh interrupt and occurs periodically.
    QUESTION:
    Is there any way I can know the subroutine nesting levels in the PBP listing? Is there any utility that can tell me this info?
    WHY:
    I am facing problems in the working of the code where I feel the subroutine has nested to level 9(which overwrites stack level 0). When un-nesting from the subroutines, I hit the level 0 routine which puts me in a hung state in the call to the subroutine that nested at level 9(0).
    thanks for any inputs
    Jerson
    Bombay, India
    Thumbs up
    Thanks Mr E
    I was searching this same forum with different words and found the very same article that you referred. Thanks very much and 3 Cheers to Darrell T. I think he has already encountered the issues I am facing now. In fact, I am already using the GetAddress macro in my programs. Something new to try.
    Still, I would like to know the nesting level without having to dig into the listing file. You know - a year from today, if I have to modify the prog, I may break something. Thats why.
    Thanks Mr E and DT
    Jerson
    the easiest solution would be to increment a variable before each gosub, and decrement before each return. Sending result to a LCD, RS232 or use an ICD to monitor it.
    sure there's some other way...
    Somehow, an interesting finding here for those using the MCS ICD.
    When you hit 'ICD Compile and program' button (or CTRL+F10), it create a variable named DEBUG_STACK which hold the value/actual level of the stack.
    NOW, to make things simple, just add those lines
    @STACK_LEVEL = DEBUG_STACK
    STACK_LEVEL  VAR BYTE EXT
    And look what happen to your STACK_LEVEL variable in the ICD window while jumping here and there with gosubs.
    i used that one...
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    START:
        PAUSE 1000
        GOSUB LEVEL1
        GOTO START
    LEVEL1:
        PAUSE 1000
        gosub LEVEL2
    LEVEL2:
        PAUSE 1000
        GOSUB LEVEL3
    LEVEL3:
        PAUSE 1000
        gosub level4
    LEVEL4:
        PAUSE 1000
    WOOOOHOOOO! Don't break my bubble to me it's a nice finding... maybe usefull one day or another. Down side... it won't work unless you use the ICD... Darrel's stuff have a BIG advantage as you just need to read the StackPTR byte variable.
    Bombay, India
    Hi Steve
    I was wondering what is this ICD thing you talk about. Is it a part of Microchip MPASM suite or MCS electronics?
    Anyhow, the latest update on my problem - I have it nailed. It wasnt the stack overflow after all. I had a case of data corruption in the event log. This particular case (case else) was not being handled leading to a program crash.
    However, come to think of it, I appreciate your helping me and discovering something in the meanwhile. How nice would it be if the Melabs team could do something in the compiler/manual to show the stack nesting level of their inbuilt functions? I think the documentation should mention this as it is a very important aspect when using Pics with 4 level stack.
    Jerson
  1. Help With stack (STKPTR)
    By rickypatel in forum mel PIC BASIC Pro
    Last Post: - 15th February 2008, 02:18
  2. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 10:04
  3. How do I drive 7 seg LCD with a PIC16f917
    By willemaajansen in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2007, 21:27
  4. Stack Under flow
    By Wayne in forum mel PIC BASIC Pro
    Last Post: - 14th September 2005, 13:22
  5. 48 level Software Stack
    Last Post: - 30th November 2003, 01:07
