basics programming
Results 1 to 4 of 4
    Feb 2007
    France Bourgoin Jallieu
    Default basics programming
    Hi Guys,
    I begin programming,
    and i still have problems with beginning.
    I want to know the correct architecture of a program with multiple choices.
    Example:
    'The program starts here
    if Choice1 goto choice1Sub
    if Choice2 goto Choice2Sub
    if Choice3 goto Choice3Sub
    Endif
    Choice1Sub:
    {Sous programme}
    Choice2Sub:
    {Sous programme}
    Choice3Sub:
    {Sous programme}
    Questions :
    Will the program read all subroutines each times or he will go to subroutines only if Choice1, 2 or 3 is validated ?
    Do i need to put "return" at the end of each subroutine to come back to the beginning of the program ?
    Olivier
    If you use GOTO you can't use RETURN.
    RETURN is only used when you jump to a routine using GOSUB.
    You don't need ENDIF if your IF statement is one one line.
    EDIT: Except for the above, the program would jump to choise2Sub if Choise2 was evaluated true. But even if none of the IF statements were true the program would run all three subs one after the other since you haven't prevented the program to reach the subs after the IF statements. Makes sense??
    It should probably look something more like:
    Start:
      if Choice1 goto choice1Sub    'Jump to choise1Sub if Choise1 is=1
    Goto start                      'Start over
    Choice1Sub:
    {Sous programme}
    Choice2Sub:
    {Sous programme}
    Goto Start			'Start over
    Choice3Sub:
    {Sous programme}
    /Henrik Olsson.
    Last edited by HenrikOlsson; - 18th February 2007 at 10:20. Reason: Forgot one thing.
    Bonjour et bienvenue Olivier,
    Yes there is many different way. If you have multiple choice on multiple var it's a little bit more coding on your side. BUT if you have multiple conditions to test on a single var, and then jump to a specific routine, you have at least 3 choices
    1. few IF THEN
            Choix VAR BYTE
    Start:
            '       some code here
            IF Choix=1 then gosub Routine1
            IF Choix=2 then gosub Routine2
            IF Choix=3 then gosub Routine3
            goto start
    Routine1:
            '   plah plah plah
    Routine2:
            '   plah plah plah
    Routine3:
            '   plah plah plah
    SELECT CASE
            Choix VAR BYTE
    Start:
            '       some code here
            SELECT CASE CHOIX
                CASE 1
                    gosub Routine1
                CASE 2
                    gosub Routine2
                CASE 3
                    gosub Routine3
                END SELECT
            goto start
    Routine1:
            '   plah plah plah
    Routine2:
            '   plah plah plah
    Routine3:
            '   plah plah plah
    BRANCHL
    but this one AS-IS, use GOTO, so, as Henrik said, you can't use RETURN without tricks
            Choix VAR BYTE
    Start:
            '       some code here
            '       choix=   0      1         2         3
            branchl choix,[Start,Routine1, Routine2, Routine3]
            goto start
    Routine1:
            '   plah plah plah
            goto start
    Routine2:
            '   plah plah plah
            goto start
    Routine3:
            '   plah plah plah
            goto start
    Feb 2007
    Smile Great
    Now i think, i have understood architecture of my program,
    Now i will try to create a sinus wave with variable duty cycle with a PIC18F458
    Olivier
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 03:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 16:51
  3. PIC programming algorithm - where is it to find?
    Last Post: - 24th June 2007, 18:31
  4. Some questions for programming
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 16:04
  5. MELab Programming
    By tarr in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2006, 13:36
