LCD black blocks problem.
Results 1 to 3 of 3
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Thumbs up LCD black blocks problem.
    Hi all,
    Yep, I had the problem that I guess most have had. Big black blocks on the first line and nothing on the second line of an LCD on a PCB made for a particular project.
    After much swearing and cursing, I decided to search this place for a possible answer......
    BINGO...The answer was found in the middle of a big long list of my search results, so I thought I'd suggest a first "try this" answer...
    It appears that some LCDs need a few seconds to initiate properly before any commands are sent to it after power up. So, after the initial DEFINES for the ports etc for the LCD, just add a PAUSE 3000 before you tell the LCD to do anything. Fixed the problem I had straight away.
    Hope this helps someone else...
    Peter Moritz.
    Peter Moritz.
    New South Wales,
    Australia.
    Jun 2005
    Wisconsin
    "It appears that some LCDs need a few seconds to initiate properly before any commands are sent to it after power up."
    I would say most if not all do. Always include a pause.
    mmm which LCD brand and model need up to 3 seconds startup???
    EDIT: may it guess? OPTREX?
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  3. LCD problem
    By Andre_Pretorius in forum General
    Last Post: - 27th January 2009, 16:47
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Need help with LCD number display.
