Replace PBP with Assembly concerning Timer0
Results 1 to 14 of 14
    Quote Originally Posted by selbstdual View Post
    What do you mean by time range ?
    Min and Max expected delay between the time you Start the Timer and 'till the comparator's output will change.
    Before we go too much into detail here: Using my method compared to the built in timer, how many more ticks does the built in timer notice ?
    Hard to say, but it can be measured with a scope + extra I/O OR by using something like Darrel suggested bellow...
    http://www.picbasic.co.uk/forum/showthread.php?t=365
    i'll do something simple here to help you to start. i think you're not as this far anyway.
    stay tunned
    In a world of german electrons
    Currently I get values between 1800 and 400 for 'Value'. Whatever, don't hurry to answer this question because my current implementation works already. This is just for finetuning...
    Feb 2005
    Kolkata-India
    Default Why don't you use interrupts?
    I would prefer using interrupts.
    Your TIMER_ZERO is already a word variable. So on a timer zero interrupt you can just increment the HighByte of the variable and normally dump the TMR0 to the lowbyte. This would make a pseudo 16bit timer. On a comparator interrupt, get the readings. It should not be very difficult in ASM . By the way what is your clock frequency and your timer0 prescaler value ? If you are using a high prescale then Darrel's Instant Interrupt may work.
    Sougata
    Difference of time(MyMethod <-> Timer0) is the linchpin of this thread. I can't see a connection between your post and the main question.
    This should not be measured. To calculate it, the timer0's speed is needed(How many cycles mean how many countings) and I want to know how fast my current implementation is(there is a number somewhere in the greatly written manual that states how much time these instructions take).
    Then I get a comparison.
    Feb 2005
    Kolkata-India
    Difference of time(MyMethod <-> Timer0) is the linchpin of this thread. .
    As far as I understood you need to get the time elapsed between two states of your comparator. You can always get two intermediate readings. Get the difference between the readings. Even if prescale is 1:1 and you are using ASM interrupts then you know how may cycles you consumed to take a reading and asjust your results thus. This should give you far more accurate results than looping around. Cause you can just stop the timer at the comparator interrupt. Get the results. I suggested a pseudo 16bit because I don't know your possible timings between comparator changes. Thus timer zero may overflow. You did ask how to handle overflow!! With the additional Highbyte incrementing on overflow you do get a 16bit timer.
    Sougata
  1. Assembly Language inside PBP
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 12th October 2009, 22:52
  2. Replies: 2
    Last Post: - 8th February 2009, 06:10
  3. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 00:55
  4. Passing arrays PBP <-> Assembly
    Last Post: - 16th April 2006, 02:01
  5. Assembly Language + PBP
    Last Post: - 10th January 2006, 14:54
