Replace PBP with Assembly concerning Timer0
Results 1 to 14 of 14
    In a world of german electrons
    Dear sougata,
    the current code looks like this:
        WHILE CMCON.6 = 0
            Value = Value + 1
        WEND
    This is all, there is no interruption. I am using the PIC 16F628A as a minion.
    I changed the code to fit my minion, but it can count only to 255 as it is an 8-Bit timer here.
    How do I deal with an overflow, means INTCON.T0IF = 1 or INTCON.2 = 1. It should be something like ValueNew = ValueOld + 256.
    Current code, not tested
    TIMER_ZERO  VAR WORD        ' VARIABLE TO STORE TIMER0
    OPTION_REG = %00000111
    INIT:
    TMR0 = 0                     'Full register contains t0-value
    INTCON.2 = 0                ' START TIMER0/Overflow-Bit = 0
    MAIN_LOOP:
        Value = Value + 1
    IF CMCON.6 != 0 THEN M   ' IF Komp.output DIFFERS THEN GET THE READING
    GOTO MAIN_LOOP
    M:
    INTCON.2 = 1                      ' STOP TIMER0/Simulate overflow
    TIMER_ZERO = TMR0            'As it is 8-Bit
    GOTO INIT                ' DO IT OVER AGAIN
    Finally Value should contain TIMER_ZERO's value.
    Wink
    Hi selbstdual,
    what do you need to count exactly? Events, internal clock tick, amount of hair lost in the process?
    Well.. what's your current project?
    Unhappy
    Hair ? Is this a joke ? I kept on laughing the whole day. Very funny.
    It is about counting the time until CMCON.6 gets a high level.
    Unhappy Rtfds ???
    Just connect pin 2 (C1OUT) to pin 9 or 12 ... and read TMR1H and TMRIL just when needed ...
    Details are in that ****ING DATA SHEET... fig 7.1
    PS: No hair lost ... was a pleasure !!!
    OR, stop the timer on a comparator interrupt...
    In meantime, is there a specific time range?
    I'll be back...
    Default Let's progress
    There is no TMR1H and L as TMR0 is 8 Bit. I cannot use TMR1 as I am using the compare-module. Additionally, Pin2 and Pin12 are used.
    I would need to check for the timer to overflow in the loop instead of reading its value. As basic is not machinecode I don't know how many tics I am missing by that method, you know ...
    MisterE: Interrupts are disabled(INTCON = 0), I am just looking at the 'time' it takes for the comparator's output to change.
    What do you mean by time range ?
    Before we go too much into detail here: Using my method compared to the built in timer, how many more ticks does the built in timer notice ?
    Quote Originally Posted by selbstdual View Post
    Min and Max expected delay between the time you Start the Timer and 'till the comparator's output will change.
    Hard to say, but it can be measured with a scope + extra I/O OR by using something like Darrel suggested bellow...
    http://www.picbasic.co.uk/forum/showthread.php?t=365
    i'll do something simple here to help you to start. i think you're not as this far anyway.
    stay tunned
    Currently I get values between 1800 and 400 for 'Value'. Whatever, don't hurry to answer this question because my current implementation works already. This is just for finetuning...
  1. Assembly Language inside PBP
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 12th October 2009, 22:52
  2. Replies: 2
    Last Post: - 8th February 2009, 06:10
  3. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 00:55
  4. Passing arrays PBP <-> Assembly
    Last Post: - 16th April 2006, 02:01
  5. Assembly Language + PBP
    Last Post: - 10th January 2006, 14:54
