PIC18F got some weird problem?
Results 1 to 14 of 14
    Jun 2005
    Penang
    Default PIC18F got some weird problem?
    Hi everyone,
    I gotta some problem with blinking my PIC18F452, which the version of PBP is 2.47 and with the latest MPASM.I changed the INC file a bit ( HS_OSC )and thats all.Is the problem could be the capacitor (0.1uf) that should be placed in the ICSP programmer(I use EPIC) which is near the header or some other thing.Below is the code :
    (BACK TO BASIC)
    Define OSC 16
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    Led_1 var PORTB.0
    Led_2 var PORTB.1
    low Led_1
    low led_2
    start:
    high led_1
    low led_1
    goto start
    and the INC file:
    ;* 18F452.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2005 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 12/16/05 *
    ;* Version : 2.47 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    "Error: PM does not support this device. Use MPASM."
    NOLIST
    LIST
    LIST p = 18F452, r = dec, w = -311, w = -230, f = inhx32
    INCLUDE "P18F452.INC" ; MPASM Header
    __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
    __CONFIG _CONFIG4L, _LVP_OFF_4L
    NOLIST
    LIST
    EEPROM_START EQU 0F00000h
    BLOCK_SIZE EQU 8
    So what could be the problem?.....
    there's one line missing...
    high led_1
    low led_1
    goto start
    Jun 2005
    Penang
    Default But..
    Thanks a lot steve,doh!!..i tried i many times but sometimes get rush!!
    But steve,sometimes it doesn't work?.
    When you say sometime it doesn't work... what do you refer to?
    programming or the blink?
    make sure you have set the EPIC software to program the config fuses. I know there's an option somewhere.
    when you program it, make sure you (or the programmer) tie/load the PGM pin to gnd.
    and the usual, Both VSS and VDD connected, 0.1 uF close to the PIC, MCLR to Vdd.
    No loose connection between the PIC and the crystal+Caps. And short distance between the PIC and the crystal.
    Jun 2005
    Penang
    Default resets itself
    I also found that it resets itself.Could it be the perfboard problem?.
    I just made SPI work between 2 PIC ( 18F452 & 18F458 ).It worked but sometimes,it resets and return to main loop although i had set BOR to lowest and make PWT enable + placed 2 npo 7 multilayer ceramic and 2 tantalum cap as near as possible to PIC.The Vreg uses LDO with good quiecent current which i belive would handle load very well.So why sometimes it resets itself?
    Jun 2005
    Penang
    Default as above
    The software part.It sometimes reset itself.I face no problem programming it as i do play with the fuses cuz sometimes you need to activate PLL and so on.So no problem with programming.Everything is ok.But,i face no idea why it don't want to for example:blink a led every 1 second..it's no "go".Maybe i spent so much time on CCS...hehehe...
    Without the whole code and schematic it's hard to say...
    Stack-Overflow reset?
    Faulty MCLR contact?
    BAD config fuses programming (LVP_ON could do some strange thing sometimes)
    messy supply line may cause some BOD reset as well
    etc etc etc
    To me scoping the VDD rail to see if it's clean and monitor the MCLR pin would be my first test...
    Well, you could still use CCS to see if the results are the same It have to be!
    Jun 2005
    Penang
    Default so..
    So,you belive this problem nothing to do with the EPIC programmer nor the software,that would be PBP version 2.47.My first thought is that the problem might come from the EPIC programmer as it was stated in the melabs website recommending a 0.1 uf cap between the power line?.Is that really neccessary?.I don't face any problem with the programming.So it's 50-50 in my mind.
    Actually , i made this circuit in perf board(donut board) or point-to-point soldering board with 16mhz crystal and a 4.7k pull-up for mclr.That's all.
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Weird code problem
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 16th March 2009, 12:16
  3. Weird Problem
    By isaac in forum General
    Last Post: - 22nd September 2008, 20:30
  4. Weird problem with 12F629
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 28th May 2005, 08:15
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 02:08
