Microphone to PIC
Results 1 to 22 of 22
    Oct 2006
    what would likely be better to use for the circuit? condenser or dynamic? can you suggest any easy method of determining the leg configuration of a 3 wire condenser mic? Thanks in advance.
    any model for this mic? is this a professionnal XLR connector or just a 3 wire capsule?
    Any picture or part # would be handy.
    Condenser or dynamic? Who knows, the best way will be to evaluate them with a pink noise and a spectrum analyser.
    Few days ago i found the following freeware for someone here. I've tried it, and i'm really impressed how good it is... for a freeware.
    http://www.sillanumsoft.com/
    Oct 2006
    It's just a simple 3 wire capsule.
    I am feeding the mic into an amplifier which will turn the signal into pulses. I want to measure the pulse width and compare the widths of the two mic inputs. The problem is I do not know what commands to use in the PBP program. I've read the manual and PULSIN seems to be a good command. I reallt need some hints on this. Thanks again very much for helping me even until this far.
    You could use Count as well. To me using the internal Timer/Counter have it's advantages.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  4. connect microphone to pic?
    Last Post: - 7th January 2008, 08:33
