hserin
Results 1 to 29 of 29
Thread: hserin
    @9600 baud AND using the internal OSC AND using SEROUT2, it's high unlikely that it will work. Using DEBUG or HSEROUT may work.
    with HSEROUT, use the following DEFINEs
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
    For ANY reliable serial comm, you really want to use a crystal or a ceramic resonator.
    Thumbs down dead end
    still canot get serial lcd driver to work
    when i use hserout i dont get anything
    with the above commands
    and really nothing shows on my scope as anything from the pic627a
    using pin 8 labeled tx
    is this the correct pin
    does not work with or without max
    really unsure which is correct
    about to return to the lcdout command and hookups
    just wanted to save pins
  1. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 12:58
  2. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 06:13
  3. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 01:38
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
