hserin
Results 1 to 29 of 29
Thread: hserin
    Default max232
    tried it with and without max works better without
    does not seem to mater still get garbarge (some) also displays corectly
    and unable to fiqure how to setup chip escape sequence
    It can't work with both cases (with and without max232) using HSER commands! Are you sure of what you are doing????
    I never used any Serial LCD's so I don't know of the ESC sequences. But with Serout commands you can drive a PC without MAX232. I am not sure if you can drive a slave device too... I'd use a MAX232 for sure.
    If this: http://www.redbinary.com/sld01a.php is the LCD driver you're using, then it looks like you'll want to use 9600 non-inverted. It should also work directly connected to your PIC hardware USART pin.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default message
    I a getting the display to work with the attached file so i assume
    hook up and baud is right
    using serout2 commandportb.7 on a 628a not using the max works better
    however i also get garbage and cannot get the esc sequence to change the display properties
    file does not compile with the latest effort to send esc
    tried others no help
    Feb 2003
    where you have "<esc>" in your code, that generally means the ASCII character "Escape" similar to how you see "<cr>" for carriage return.
    Try replacing that with 27 or $1B and see how you get on. (No difference between them except that 27 is decimal and $1B is hex.)
    Keith
    www.diyha.co.uk
    www.kat5.tv
    @9600 baud AND using the internal OSC AND using SEROUT2, it's high unlikely that it will work. Using DEBUG or HSEROUT may work.
    with HSEROUT, use the following DEFINEs
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
    For ANY reliable serial comm, you really want to use a crystal or a ceramic resonator.
    Thumbs down dead end
    still canot get serial lcd driver to work
    when i use hserout i dont get anything
    with the above commands
    and really nothing shows on my scope as anything from the pic627a
    using pin 8 labeled tx
    is this the correct pin
    does not work with or without max
    really unsure which is correct
    about to return to the lcdout command and hookups
    just wanted to save pins
  1. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 12:58
  2. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 06:13
  3. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 01:38
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
