hserin
Results 1 to 29 of 29
Thread: hserin
    Quote Originally Posted by jcleaver View Post
    using microstudio for boot loader but have tried no loader with the same results using a serial lcd from redbinary lcd is 2 * 16 it does display its strartup message so assume electrical is ok they onmly deal with c programing not much i know about that (nothing)
    Here's your code with a couple of tweaks, have not tested it though:
    '*  Author  : JACK CLEAVER                                      *
    '*  Notice  : Copyright (c) 2007 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 2/17/2007                                         *
    @MyConfig = _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_ON
    @MyConfig = MyConfig & _BODEN_OFF
    @ __config  MyConfig    ; sets your programmer's "fuses"
    TRISB = %11111110 ' ALL B AS INPUTS EXCEPT B.0
    TRISA = %11111111 ' ALL a as inputs
    INCLUDE "Modedefs.bas"  ' This is a must have for serial communications using serout
    CMCON  = 7  ' turn off comparators
    ADCON1 = 7  ' turn off a/d converter
    DEFINE PIC16F877A
    DEFINE OSC 20
    DEFINE      LOADER_USED 1   ' Boot-Loader is being used
    DEFINE      OSC 20          ' We're using a 20MHz oscillator
    DEFINE CHAR_PACING 1000
    x var byte
      w1 var byte
    w1 =0
    Setup:
    w1 = 1
    pause 1400
    for x = 1 to 6
      SEROUT portb.0,6, ["ABCD", #w1] 'mode 6 = N9600 mode 2 = T9600
      w1 = w1 + 1
      PAUSE 250
      next x
      GOTO Main
    Red face thanks
    thanks for the reply will try this have moved display over to a 628a and get
    fairly good some garbage dont know what that is
    also trying to send a escape sequence to set up the serial chip
    but that does not work any ideas on this tried
    dec 27 or hex 27 or "<esc>" not working
    interesting will not display esc here with the <>
    also why the garbarge do want to move this back to 677a so will be trying your setting
    again thanks for the feedback
    Did you put a max232 or similar device between your LCD and PIC?
    Default max232
    tried it with and without max works better without
    does not seem to mater still get garbarge (some) also displays corectly
    and unable to fiqure how to setup chip escape sequence
    It can't work with both cases (with and without max232) using HSER commands! Are you sure of what you are doing????
    I never used any Serial LCD's so I don't know of the ESC sequences. But with Serout commands you can drive a PC without MAX232. I am not sure if you can drive a slave device too... I'd use a MAX232 for sure.
    If this: http://www.redbinary.com/sld01a.php is the LCD driver you're using, then it looks like you'll want to use 9600 non-inverted. It should also work directly connected to your PIC hardware USART pin.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default message
    I a getting the display to work with the attached file so i assume
    hook up and baud is right
    using serout2 commandportb.7 on a 628a not using the max works better
    however i also get garbage and cannot get the esc sequence to change the display properties
    file does not compile with the latest effort to send esc
    tried others no help
  1. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 12:58
  2. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 06:13
  3. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 12:48
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 01:38
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
