hserin
Results 1 to 29 of 29
Thread: hserin
    Quote Originally Posted by jcleaver View Post
    pbp list 4 commands
    hserin hserout
    hserin2 hserout2
    would like to know how these pins are labled on the pic
    apparently you do not use pin numbers with this command
    Page 75 and 79 of your PBP manual.
    Default ?
    read the manual lots of info to digest maybe i missed it
    but only reference to pin # says to look at the pic documentation
    thats fine but how are the labled?
    does the 16f877a have these wre this something on newer pics
    Page 75 and 79 of your PBP manual...2nd paragraph of each page. Compare that to Page 111 of the 16F877 datasheet.
    Thumbs down manual
    when i purchased pbp it was because it was simple to use and did not require
    master in programming or microchip documentation or much assembly
    that has not been the case with what i have done so for
    read the pic manual pg 113 which talks about this
    all i wanted was a description of how the pins for this were labled
    so i coulkd test this part of the pbp manual
    guess i am over my head again do not see descriptors
    i know there are pin liabled rx and tx but these are being used to connect to mcs
    I was just trying to learn you something so you could figure other stuff out in the future...
    HSERIN = receiving serial data = USART receiver = RX
    HSEROUT = transmitting serial data = USART transmitter = TX
    If the RX and TX on your particular chip in your particular system are already being used by something else, such as the MCS (which is what?), then you probably can't use HSERIN/HSEROUT without circuit mod's.
    Default thanks
    i know and i appreicate that however just at the begining stage and only a hobby
    so just trying to get some experience with pbp not pics
    mcs is microstudio plus
    does this pic have hserout2???
    Default continued
    i guess my main problem is i am trying to get data to a serial lcd driver
    and cant get it to work even though there seems to be data from the pic
    thats why i wanterd to try the various commands for serout to get this working this seems to be a tough area for me
    thanks
    What does the datasheet say as far as the number of USARTs (also reference the PBP manual, page 78, 2nd paragraph)?
    I understand you're trying to get experience with MCS/PBP and not PICs, but what is MCS/PBP without a PIC? Just an expensive text editor...
  1. HSERIN and XOUT command
    By aratti in forum General
    Last Post: - 12th May 2009, 11:58
  2. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 05:13
  3. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 11:48
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 00:38
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 15:42
