IF..THEN syntax
Results 1 to 40 of 53
Thread: IF..THEN syntax
    Oct 2006
    Default IF..THEN syntax
    I agree that the version I'm using is old but the program I tried to compile was also more or less 6 years old. anyway im pasting the whole program here for you to inspect. Thanks!
    'Read Cds cell #1 on port b line 1
    'Read Cds cell #2 on port b line 7
    v1 var byte 'Variable v1 holds Cds #1 information
    v2 var byte 'Variable v2 holds Cds #2 information
    v3 var byte 'Variable for calculation
    s1 var byte 'Variable s1 holds servomotor #1 pulse width info
    s2 VAR word 'variable for random function
    rv var byte 'variable rv holds the range value
    s1 = 150 'initialize steering servomotor facing forward
    rv = 10 'Adjust as needed for operation
    ct var byte 'counter
    start:
    pot portb.2,255,v1
    pot portb.3,255,v2
    'Check bumper switch "Did I hit something?"
    if porta.0 = 0 then avoid 'Hit obstacle go into avoid mode
    'Is it sleepy time?
    if v1 <= 230 then skp 'Is it dark enough to sleep?
    if v2 > 230 then slp 'Yes
    'Is it too bright to see?
    skp:
    if v1 >= 12 then skip2
    if v2 < 12 then avoid
    'Which way do I go?
    skip2:
    if v1 = v2 then straight
    if v1 > v2 then greater
    if v1 < v2 then lesser
    straight:
    pulsout portb.6, s1
    pulsout portb.7, 157
    goto start
    greater:
    v3 = v1 - v2
    if v3 > rv then right
    goto straight
    lesser:
    v3 = v2 - v1
    if v3 > rv then left
    goto straight
    right:
    s1 = s1 + 1
    if s1 > 225 then s1 = 225
    pulsout portb.6, s1
    pulsout portb.7, 165
    goto start
    left:
    s1 = s1 - 1
    if s1 < 65 then s1 = 65
    pulsout portb.6, s1
    goto start
    slp:
    pulsout portb.6, s1
    pulsout portb.7, 167
    goto start
    avoid:
    random s2
    s1 = s2 / 256
    for ct = 1 to 125
    pulsout portb.6, s1
    pulsout portb.7, 177
    pause 18
    next ct
    s1 = 150
    goto start
    I just compiled it here for a 16F877. PBP 2.46
    No errors.
    Oct 2006
    No errors.
    I'm compiling it for a 16F84 with PBP 2.3
    That's the only version I have because I can't afford to buy or upgrade.. I hope you understand :-)
    Compiled it for 16F84, still no errors.
    You might consider
    http://www.compilespot.com
    It's a low monthly subscription that will allow you to use the latest compiler version. If you're fast enough, you may only need to pay for 1 month.
    regards,
    Oct 2006
    [QUOTE=Darrel Taylor;32729]Compiled it for 16F84, still no errors.
    QUOTE]
    in that case, could you please send me the .HEX file so that I could load it to my PIC micro if that is ok with you?
    P.S. I sent you a PM
    :-D
    It sounds like an easy thing. It's already compiled, just send you the .HEX file.
    But, being Asst_Admin on this forum, if I started compiling things for someone, I'd have 100 people a day that didn't want to buy the compiler, sending me their files.
    That wouldn't be fair to the people that had to pay for their compiler.
    Oct 2006
    well, ok then. then pls suggest any other options if its ok with you. :-)
    Oct 2006
    Quote Originally Posted by scaenix View Post
    start:
    pot portb.2,255,v1
    pot portb.3,255,v2
    'Is it sleepy time?
    skp:
    'Which way do I go?
    skip2:
    straight:
    pulsout portb.6, s1
    goto start
    greater:
    v3 = v1 - v2
    goto straight
    lesser:
    v3 = v2 - v1
    goto straight
    right:
    s1 = s1 + 1
    pulsout portb.6, s1
    goto start
    left:
    s1 = s1 - 1
    pulsout portb.6, s1
    goto start
    slp:
    pulsout portb.6, s1
    goto start
    avoid:
    random s2
    s1 = s2 / 256
    for ct = 1 to 125
    pulsout portb.6, s1
    pause 18
    next ct
    s1 = 150
    goto start
    I've quoted the code I've posted in one of the previous replies. the program is supposed to make the servomotor #1, which is connected to RB7 stop when in total darkness. I'm confused why the motor still continues on turning even if it is supposed to stop. Please anyone enlighten me on this. Thanks very much!
    I didn't read the whole thing but here's one fast suggestion for you.
    Pulsout have to return the pin to it's previous state right? but nowhere the initial state have been set. When you turn on a PIC, the state of all pin is hard to predict. add those lines at the top of your code.
    PORTB=0    ' Clear all PORTB pin
    TRISB=0     ' Set all PORTB pins to output
    if it doesn't work, you could still place a LOW PORTB.7 after each PULSOUT.
    Mar 2005
    Iowa, USA
    start:
    pot portb.2,255,v1
    pot portb.3,255,v2
    My guess is the values in v1 and v2 are are not as expected. Pot command can be a pain at times. Do you have anyway of sending these values to an LCD to debug?
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Oct 2006
    With the current program, clearing the all PORTB pins and setting them all for output couldn't seem to work since portb.2 and portb.3 are used for storing the Cds values which serve as input. I've tried adding LOW PORTB.7 after each pulsout but it still doesn't work. About the LCD thing, I'll try it when I get to school since that is the only place where the LCD is available. I'll update you when I get the results.
    Oct 2006
    hmm..can anyone please tell me what command to send to a servo motor -- a modified one for continuous rotation-- in order for it to stop? Thanks!
    Oct 2006
    Oh well! Howdy! I've finally figured it out. I've figured out how to stop the servo motor and adding a reverse functionality to it. Thanks for the help guys! Thanks very much for all the helpful post. More power to all!
  1. Endless supply of 'syntax error's.
    By BitHead in forum mel PIC BASIC Pro
    Last Post: - 14th December 2009, 20:21
  2. Replies: 0
    Last Post: - 1st September 2008, 07:03
  3. Math operations & Syntax?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2008, 01:40
  4. Need help with I2C syntax problem?
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 19:11
  5. Syntax error PIC16F684
    By milestag in forum mel PIC BASIC Pro
    Last Post: - 21st September 2005, 18:54
