vfd
Results 1 to 6 of 6
Thread: vfd
    Thumbs up vfd
    any body done any hookups on the noritake displays
    and hints ideas would be appreicated
    looking at the graphic model gu128x32
    or might try the 4 line alphanurmeric
    Default Zillion
    Be careful if you buy used VFD as Noritaki makes a zillion of them to manufacturers specs, not to standards and hook up diagrams reall a P.I.A. to get. There are VFDs that follow the Hitachi LCD standards and are interchangable.
    Wink ok
    where the best place to get the 4 line display with same hookup and commands as the lcd we use with the pic
    jcleaver, I have used in the past both the 2x40 and 4x20 noritake displays
    model numbers CU40025SCPB-W6J and CU40025SCPB-W5J respectivley. Both work with all LCDOUT commands per PBP. I had no problems and they connect just like the normal parallel lcd displays.
    Jun 2004
    Default vfd
    Have used hitachi standard VFD in many PIC products without problems.
    I get mine from Farnell.
    Default Like I said
    I bought a new Futaba NA202MD12Aa from an ebay seller who has lots of them for cheap. Guess what - no data to be found - none that was real anyway, like I said, VFDs are great, just make sure of what you are buying and you will be happy. Elsewise you get some paperweights. Some of the forum users have made recommendations. I would venture to say those are safe choices. Try 'em.
    For places where there is high ambiant light you can't beat them. I recant my statement of above RE: Noritaki makes . . of that I am not sure, but there are zillions of surplus vfd units out there that are non standard, and that was my point, not to badmouth noritaki.
    JS
  1. VFD pinout and connections
    By rshaver in forum mel PIC BASIC Pro
    Last Post: - 26th October 2010, 05:48
  2. VFD and HPWM
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 12th January 2009, 02:12
  3. displays
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 10th February 2007, 22:14
  4. New Products & Sale Items
    By Bruce in forum Adverts
    Last Post: - 21st February 2005, 23:04
