Change From C to PBP
Results 1 to 2 of 2
    Jun 2006
    Default Change From C to PBP
    I have the code below in C
    Anyone know to change from c to PBP
    void test() {     //Generate test signal
      while (1){
        PORTB &= 0xee;  // sends a ground to the SCR gate
        delay_us(56);   // 56 us delay
        PORTB |= 0x11;   // ground off the SCR
        if (PORTB & 0x04) delay_ms(200); //300 rpm
        else delay_ms(8); //7500 RPM
    void main() {
    const char tspark[]={ 0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  1,  3,  3,  5,  5,  7,  7,  9,  9,  10,  12,  12,  12,  14,  14,  14,  17,  17,  17,  20,  20,  20,  22,  23,  25,  25,  28,  28,  31,  31,  34,  34,  37,  38,  40,  41,  44,  44,  44,  48,  48,  48,  51,  52,  52,  53,  56,  56,  57,  57,  61,  61,  62,  62,  63,  63,  63,
          64,  64,  68,  68,  69,  69,  70,  70,  71,  71,  72,  72,  73,  73,  74,  74,  75,  75,  79,  80,  80,  81,  81,  82,  82,  83,  83,  84,  84,  85,  85,  86,  90,  91,  91,  92,  92,  93,  93,  94,  94,  95,  96,  96,  97,  97,  98,  98,  99,  99,  100,  100,  101,  106,  106,  107,  107,  108,  108,  109,  110,  110,  111,  111,  112,  112,  113,  113,  114,  115,  115,  116,  116,  117,  117,  118,  118,  119,  120,  120,  121,  121,  122,  122,  123,  123,  124,  125,  125,  126,  126,  127,  127,  128,  128,  129,  130,  130,  131,  131,  132,  132,  133,  133,  134,  134,  135,  136,  136,  137,  137,  138,  138,  139,  140,  140,  141,  141,  142};
      short int spark=0;
      unsigned int tspk, t0,t1,low;
      unsigned int ofc; //Holds number of overflows
      const unsigned int LowDelay=25;   //Delay <1832 RPM, in degrees
      const unsigned int ld=360/LowDelay; //Dont change this
      TRISB = 0x0E;      // set RB1,2,3 for input, all others for output RB0=SCR RB4=Strobe
      PORTB = 0x11;      // set gate to SCR high i.e pin 6 of PIC +strobe
      OPTION_REG = 0x06; // tmr0 SOURCE INT CLOCK, 1:128 PRESCALER
      INTCON = 0x00;     //Disable interrupts +Resets interrupt flags
      TMR2 = 0;          //Reset timer2
      TMR0 = 0;          //Reser timer0
      PR2 = 255;         //This is how far timer2 counts before overflow
      T2CON = 0x07;      // start TMR2 counter 1:16
      if (PORTB.F3) test(); //If test jumper is on jump to test function
      while(1){           //Loop forever
        ofc=0;            //Reset overflow counter
        while(PORTB & 0x02){ //Wait for low pulse on Hall switch
          if  (INTCON&4) {    //Overflow
            ofc++;            //Increase overflow counter
            INTCON = 0x00;    //Resets interrupt flags
          spark = 1;
        }                    //North pole of magnet has passed
        if(spark){
          t0 = TMR0;
          TMR0 = 0;          //Start new rev count
          if(ofc > 0) {      //Overflow timer0, we have < 1832 RPM
            if ( ofc >= 36) ofc=36; //Min RPM 50 to avoid big calculations
            low=ofc*ld;       //Simplified calculation, gives about 25 degrees
            delay_cyc (low);  //extra delay based on overflow counter
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);    //Repeat 16 times - prescaler
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            delay_cyc (low);
            }                   //max255 -> 2550 cycles
          tspk = tspark[t0]; //use table lookup for spark delay
          T2CON = 0x07;      //start TMR2 counter 1:16
          TMR2= 0;           //clear spark timer
          while(TMR2 < tspk);//loop until timeout to send spark
          PORTB &= 0xee;     //sends a ground to the SCR gate
          delay_us(56);      //56 us delay
          PORTB |= 0x11;     //ground off the SCR
          spark = 0;
      } //if(spark)
    } //while(1)
    } //main
    Bombay, India
    Default Yes
    Yes. For Starters
      while (1){
    converts to this
    Test:
       while 1
          Portb = PortB & $ee
          pauseus 56
          Portb = PortB | $11
          if Portb & 4 then
             pause 200
             pause 8
       wend
    Jerson
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. PBP IF,THEN help
    By paulcox82 in forum mel PIC BASIC Pro
    Last Post: - 27th September 2009, 21:08
  3. Replies: 2
    Last Post: - 8th February 2009, 06:10
  4. Using PICBASIC PRO in MPLAB IDE
    By jblackann in forum General
    Last Post: - 4th May 2008, 10:20
  5. Compiler differences between PBP 2.33 & 2.46
    Last Post: - 2nd May 2006, 20:01
