mister e..
im not sure what good a list of applications is.. i was just interested in seeing something else done with the usb pics.... hopefully some source and a schematic..
yes bruce.. something like that..
what dare i ask is it?
mister e..
It's an unfinished project I started, and never had time to finish. You're welcome to the source code http://www.rentron.com/PicBasic/PIC_USB.htm
When I get time I'll finish the article. It uses a LAB-XUSB board from MeLabs, DS18B20 temp sensor, and EasyHID.
bruce!
yeah.. that is great... now if only i was smart enough to convert the vb6 files to .net...
soon i will start a new thread about that.. i figured out most of the errors.. there is just 1 or 2 left... they may be hard ones though...
I definiately will contribute something soon.. I made a 'gestural controller' project using tilt switches, a hacked mouse, a BS2, RS232 and VB6.
i want to get this to be a USB pic and .net and then i will share it. ive slowly been working that direction.. an article\tutorial about the BS2 portion is almost done... should be up in a few days
Hi Robert,
I have a friend that's also working on a VB.Net app with EasyHID. If we get something going before you, I'll let you know.
Commercial DIY KIT that I designed back in 2005. Real-world interface using RS232 or USB with a converter or chip upgrade to 18f4550 with the inclusion of new firmware and slight PC-board mods. (Have not done this as of yet) Nice Windows-based GUI allows for a lot of experimentation. I do have some regrets with the design - if I had to do it all again I'd definitely do things much different. My second PIC related project, so I'm not kicking myself too hard. It was published in the Silicon Chip magazine back in Nov 2005 and is currently on sale at Dick Smith electronics for $49 !!! RRP: $99, so go grab yourself a bargain everyone! PIC16f877a @ 4MHz
Specs:
10 Digital Inputs
10 Digital Outs
2 ADC – (0-5) & (0-25)
2 Onboard Relays
1 Onboard Buzzer
1 Channel For Temp
1 Channel For Resistance
*Great buy at $49 AUS - parts alone would cost this!
http://www.dse.com.au/cgi-bin/dse.st...uct/View/K3090
Best Regards,
Trent Jackson
.net might not be able to handle those API calls. Does .net have support for calls from the gdi32 library, like Bitblt? I heard it doesn’t! I submitted an NES emulator to Planet Source code a while back, written in VB5, got some feedback from someone who attempted to port it to .net Apparently, it didn't turn out too well, resulting in nothing but compile errors. Can't run emulator in IDE - too slow.
Trent Jackson
Hi Trent,
Search "Unmanaged Code".
.NET Development (General) Technical Articles
An Overview of Managed/Unmanaged Code Interoperability:
http://msdn2.microsoft.com/en-us/library/ms973872.aspx
Best regards,
Luciano
Trent,
I havent worked on it in a few week (building a CNC machine right now), but, i do remember getting very close to a working easyHID example in .net.
The api stuff seemed fine, the problem was a slight change in the syntax of some portion of the code i do not understand!
someday i may be begging for more help here, with more specifics! in the meantime, just try and convert the USBDemo code to .net.. It ALMOST works!
-R
I don't pretend to know a great deal about .net, not even for a millisecond. I don't have it and have never used it...
My suggestion: Post the project on Planet Source Code in both the VB and .net Worlds. Good chance you'll get feedback from someone who might be able to help.
http://www.planet-source-code.com
Best Regards,
Trent Jackson
