A flag is just a bit that you set or reset at one (ore more) point in the program and then read at another point. Sort of a one bit memory if you will.
/Henrik Olsson.Code:myFlag VAR BIT 'This is a single bit flag. Flags VAR BYTE 'Variable containig 8 bits ("flags"). Flag0 VAR Flags.0 'This points to the first bit in Flags Flag1 VAR Flags.1 'This points to the second bit in Flags DisplayON VAR Flags.2 'Another flag in the 'flag-byte' ' //And so on.... Main: If Flag0 = 1 then 'Is Flag0 set? High Portb.0 'If so set PortB.0 High Else Low PortB.0 'If not, set it low Endif If PortA.0 = 1 AND PORTA.1 = 0 then Flag1 = 1 'If so Else Flag1 = 0 Endif ' //And so on...
