sleep dependant on 12v source
Results 1 to 2 of 2
    BTlab's Avatar
    BTlab Guest
    Default sleep dependant on 12v source
    Hi all,
    Im currently building an automotive project using a 16F876, and I'm nearing completion but one last thing is that I want the pic to sleep when it is not receiving power from accessory (+12v), so that the variables do not get erased when the car is switched off
    the project contains an LCD which I also wish to shut down.
    what is the best way to acheive this? would I have to run the 12v through another regulator or can it be done some other way?
    code wise I guess I just use port change interrupt?
    Mentor, Ohio
    Smile
    Hi BTlab,
    Why don't you just write your variables to eeprom just before the power to the PIC dies then read them back into your program when the PIC powers up again? Use the READ and WRITE commands. You should also have an input that monitors the incoming power supply and put a 100uF capacitor across the PICs power to keep alive long enough to store the variables in memory. I believe there have been previous questions about this on the forum in the past.
    HTH,
    BobK
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Filling pdu array with gps data!
    By camolas in forum mel PIC BASIC Pro
    Last Post: - 4th October 2008, 00:54
  3. Replies: 0
    Last Post: - 15th December 2006, 19:16
  4. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  5. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
