Hello,
I use two AD channel on PIC 16F877. Until interrupt pulse measure value on channel 0 and channel 1 with 2 ms delay. On AD pins have voltage divider with resistor.(from 9V to 4,5V). Problem is similar without divider.
Major problem is:
When tied pin2 from AD channel 0 to VCC (5V) shown value 294 (2,6V in my case). Channel 1 is on GND
and then tied channel 1 to VCC (5V) value on CH0 is now 511 (4,5V in my case).
I not understand why don't must be each channel separated for correct result. Is my ADCON setting correct?
TNX,
Samo
Part of my routine is:
@ DEVICE PIC16F877, HS_OSC
DEFINE OSC 20
DEFINE LCD_DREG PORTD
DEFINE LCD_DBIT 4
DEFINE LCD_RSREG PORTC
DEFINE LCD_RSBIT 6
DEFINE LCD_EREG PORTC
DEFINE LCD_EBIT 7
DEFINE LCD_BITS 4
DEFINE LCD_LINES 4
DEFINE LCD_COMMANDUS 2000
DEFINE LCD_DATAUS 50
DEFINE ADC_BITS 10
DEFINE ADC_CLOCK_2
DEFINE ADC_SAMPLEUS 3
TRISA=%11111111
ADCON1=%10010111
T1CON=%00110100 ' Set TIMER1
ANALOG1 VAR PORTA.0 'ANALOGNI VHOD1
ANALOG2 VAR PORTA.1 'ANALOGNI VHOD2
ANALOG3 VAR PORTA.3 'ANALOGNI VHOD3
INTER VAR PORTB.0 'INTERRUPT
IZHOD2 VAR PORTA.2 'IZHOD2
IZHOD1 VAR PORTB.4 'IZHOD1
IZHOD5 VAR PORTB.1 'IZHOD5
IZHOD4 VAR PORTB.2 'IZHOD4
IZHOD3 VAR PORTB.3 'IZHOD3
IZHOD1A VAR PORTA.4 'IZHOD1A
IZHOD2A VAR PORTA.5 'IZHOD2A
SCL VAR PORTA.6 'I2C CLOCK
SDA VAR PORTA.7 'I2C DATA
TSET VAR PORTB.5 'TIPKA SET
TUP VAR PORTB.6 'TIPKA UP
TDN VAR PORTB.7 'TIPKA DOWN
LED1A VAR PORTC.4 'LED1A
MERITEV1 VAR WORD
MERITEV2 VAR WORD
MER1 VAR WORD
MER2 VAR WORD
MER2A VAR WORD
MER2B VAR WORD
MER2X VAR WORD
MER1A VAR WORD
MER1B VAR WORD
MER1X VAR WORD
MER2Y VAR WORD
MER1Y VAR WORD
LCDOUT $FE,$40,$10,$10,$08,$04,$02,$01,$01,$01 '\
LCDOUT $FE,$48,$01,$01,$01,$01,$01,$01,$01,$01 'I
LCDOUT $FE,$50,$00,$00,$00,$00,$00,$00,$00,$1F 'I
LCDOUT $FE,1
On Interrupt Goto SAMPLE ' Define interrupt handler
INTCON = $90 ' Enable INTE interrupt
MAIN: MER1=MERITEV1/112
MER1Y=MERITEV1//112
MER1X=(MER1Y*10)/112
MER2=MERITEV2/112
MER2Y=MERITEV2//112
MER2X=(MER1Y*10)/112
LCDOut $FE,2,1,0,#MER1,".",#MER1X,"V"
LCDOut $FE, $C0,1,1,2,2,#MERITEV1
LCDOut $FE, $90,1," ",1,#MER2,".",#MER2X,"V"
LCDOut $FE, $D0,1," ",1,#MERITEV2
LOW LED1A
GOTO MAIN
Disable
SAMPLE: ADCIN 0,MERITEV1
PAUSE 2
ADCIN 1,MERITEV2
HIGH LED1A
INTCON.1 = 0 ' Clear interrupt flag
Resume
Enable
GOTO MAIN
