Switchmode halogen transformer question
Results 1 to 3 of 3
    New Zealand
    Default Switchmode halogen transformer question
    I've got an electric forkhoist and want to make an internal charger for it (controlled by a PIC of course) Was thinking about strapping a heap of those cheap halogen transformers together - my question is tho, can they be put together - I've hooked normal switchmode supplies in parallel and series before but never these cheap transformers and not sure if it's possible.
    The battery is 36V, so I figure the transformers r 11.5V each will need 4 in series to make 46V to charge it. And then if I parallel two sets, should get 36A out of 8 200VA transformers.
    Then the idea is to PWM the output to change between charge, equalize and trickle at the end.
    Would love to hear any thoughts on the idea, cheers
    Italy
    What is the price for new batteries if something goes wrong?
    Why not something like that:
    http://www.battery-chargers.com/catalog/25.pdf
    USD 279.00
    http://www.batterystuff.com/battery-...ti-volt-input/
    Ask the manufacturer if it can be permanently installed on a vehicle.
    From the picture it is not protected against rain. The charger must be
    built to sustain vibrations.
    DANGER! If the charger is permanently installed on the vehicle
    there is danger of electrocution when you touch the vehicle.
    DANGER! RISK OF BATTERY EXPLOSION FROM HYDROGEN GAS.
    MAY RESULT IN BLINDNESS, SERIOUS INJURY, PERMANENT
    DISFIGUREMENT AND SCARRING.
    Best regards,
    Luciano
    Quote Originally Posted by Luciano
    Bah... it's a nice anti theft system
  1. Timer0 Instant Interrupts Question
    By wmarchewka in forum mel PIC BASIC Pro
    Last Post: - 14th December 2009, 05:29
  2. ADC input using a current transformer?
    Last Post: - 12th May 2009, 22:13
  3. 24VAC Transformer from Air Handler, 7805
    By nemesis in forum Schematics
    Last Post: - 25th February 2009, 19:23
  4. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
