18F458 to PC communication Help
Results 1 to 5 of 5
Threaded View
  1. #3
    As you stated you're using the Bootloader and unless you want to add an additional serial PORT and/or save a MAX232, there's no reason to use SEROUT.
    This said, if you don't use the Bootloader, i can't confirm it will never cause any problem if you leave the DEFINE LOADER_USED 1 line...
    On most setup, a simple 1k resistor in serie work using the inverted mode (N2400).. if you don't forget to connect the PC and PIC gnd together...
    If you're using the Bootloader, you MUST disable the DTR control line in your VB program or The MCLR will always be set to GND. Make sure you also disable the handshaking. As Henrik suggested, do some simple test in MicroCode Studio's Serial Communicator to begin.
  1. Replies: 11
    Last Post: - 12th July 2008, 03:36
  2. Communication between PC and PIC16f876
    By knsteam in forum Serial
    Last Post: - 26th June 2007, 10:59
  3. Replies: 5
    Last Post: - 20th March 2006, 02:34
  4. Pic18F4455 to PC communication RS232
    By anmproj in forum mel PIC BASIC Pro
    Last Post: - 30th July 2005, 03:32
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
