'Soft' On/Off Power Switch
Results 1 to 20 of 20
    Apart from the Resistor connection that Ski mentioned (which is there to keep Q1 switched OFF), it is the job of your PIC to drive RA1 high BEFORE the User removes his finger from the switch. If your software has delays or other things before it sets RA1 high, then the circuit will simply switch-off when the finger is taken off the switch.
    It is a simple circuit - it can't fail. As long as the Base of Q1 is driven low (what is your value for R2 and what is the current draw via Q1?), it will conduct and supply power. Check your wiring and software and value for R2. Remember (simplistically) the gain (hfe) value for your chosen Transistor together with the current you're sucking out the Collector will determine the amount of cuurent you need to put into the Base. Your chosen R2 may be too high a value.
    SWITZERLAND (french speaking)
    Yup, R1 is actually connected du Q1's base. Thanks for noticing, skimask.
    My drawing only is incorrect, in fact, I built this circuit according to Melanie's plan in a previous post.
    The values of the components are those stated in the same previous post.
    Quote Originally Posted by Melanie
    Q1 BC327B (most any PNP transistor)
    Q2 BC547B (most any NPN transistor)
    D1, D2 1N4148 (or equivallent low-power signal Diode)
    R1 22K
    R2, R3, and R4 12K
    There is no delay in the program. In fact, I set RA1 high at the very beginning of the code.
    At startup, the circuit draws 4,5 mA. A few milliseconds later, the current peaks up to 600mA (I drive an IR led - it's a remote control).
    I'm going to add another Tr to provide the "power" to the IR-led instead of using only Q1. This should solve the problem.
    Roger
    May 2006
    Del Rio, TX, USA
    Red face
    Simple, but need to ask. Are you sure RA1 is set to digital?
    Default everythink is okay
    I checked an re-checked all over again; I even changed my breaboard.
    Finally, I tested all components and surprise: R2 has infinite resistance (should be 12k!).
    Everything is fine and the circuit works well now.
    Thank you to All for your help.
    I add the corrected shema - hope I didn't made a mistake this time.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2707&stc=1&d=121484865 4">
    Roger
    Sep 2008
    Maine, USA
    Default Simplified circuit
    If all you need is a push button to turn on the circuit and the PIC to turn it off then I have tested a simplified circuit that uses a MOSFET. Low part count = lower cost! I didn't have a P-MOSFET laying around, but I *think* that you could replace my Q1 with one and that would eliminate R2 in my circuit too.
    Guy
    Quote Originally Posted by tekart View Post
    Guy
    Hello,
    ¿You can replace the transistor by a canal N?.
    Thank you
  1. Switch mode power supply Pic Micro
    Last Post: - 29th July 2009, 14:11
  2. Replies: 3
    Last Post: - 29th April 2009, 01:45
  3. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  4. Switch PIC16F877 ON/OFF
    Last Post: - 27th August 2005, 13:34
  5. Electronic 'Soft' Power Switch
    By Art in forum Schematics
    Last Post: - 11th August 2003, 00:50
