'Soft' On/Off Power Switch
Results 1 to 20 of 20
    The 'load' is connected between the Collector of Q1 and 0v.
    Aug 2005
    Houston, TX
    Default See Auto-off under schematics
    My final circuit, sort of like Melanie's, works perfectly as far as I can tell. I have no quick button problem, perhaps because I put a decoupling cap., .1uf, in the circuit.
    AMay
    Smile doubts
    Hello,
    Do I want to connect a load with a battery of 9V, like I make to connect the pic with 5V and that it doesn't consummate a lot?.
    Thank you
    Smile
    Can this work this way?
    That will work to turn your PIC ON, and have the PIC switch OFF... D2 and R4 are then not required.
    However, if you require a Button-OFF function, then you need to tell the PIC that the Button has been pressed. In that case D2 and R4 are required and in your circuit you will then have omitted to take a line from the D2/R4 junction back to an available PIC pin.
    Smile
    Melanie,
    Thank you very much by its aid.
    SWITZERLAND (french speaking)
    Unhappy Turn-On won't work...
    I do have difficulties to make this circuit switch-ON.
    Problem description: if I switch-off my power-supply for about 2 to 3 minutes and switch it on back again, the soft-switch won't function and power the PIC. But once the PIC has been "successfully" powered, it works any time (as long as I don't switch-off the supply again).
    For Q1, I implemented a 2N3906, then aBC307, then BC557; no way to make it work. Finally an old (metal case) 2n2905.
    By "chance", I got it to work by making a false-contact between the 2n2905's (Collector is connected to case) and R1 (any pole) on the breadboard.
    Once the contact has shortly happened and as long as the power-supply is not disconnected, the soft-switch will work perfectly (!?).
    What shall I do to correct this?
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2705&stc=1&d=121475975 5">
    NB: I didn't implement D2 + R3 since the program shuts-off the circuit by program (RA1 = 0).
    Roger
  1. Switch mode power supply Pic Micro
    Last Post: - 29th July 2009, 14:11
  2. Replies: 3
    Last Post: - 29th April 2009, 01:45
  3. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  4. Switch PIC16F877 ON/OFF
    Last Post: - 27th August 2005, 13:34
  5. Electronic 'Soft' Power Switch
    By Art in forum Schematics
    Last Post: - 11th August 2003, 00:50
