USB Serial Communication Continuous
Results 1 to 17 of 17
    Feb 2007
    I've never tried with a DEFINE OSC 20... but i think it's the main problem.
    Look how i did it in mine. (config fuse as well)
    I have tried it with a DEFINE OSC 48 as well....infact the USB interface works fine...i tried to switch on/off the LED pins on you demo and they work ...
    The config fuses are
    24 0E 3E 00 00 83 81 00 0F C0 0F E0 0F 40
    in either case (48 or 20)
    i have defined the PLL and OSC setting in the .inc file so the DEFINE directive has no effect
    in the case of :
    DoLow:
    LOW PORTC.0
    USBSERVICE
    PAUSE 30
    USBSERVICE
    i found that this code does work...and it does generate a delay of 30ms on the Oscilloscope without affecting the Tx USB connection....The TX seems to be transmitting fine...
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  2. Serial data to USB
    By cooksydesign in forum USB
    Last Post: - 29th October 2008, 16:10
  3. USB and serial cable connection(s)
    By ardhuru in forum Schematics
    Last Post: - 18th August 2008, 16:26
  4. Bafo USB to serial adapter
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 29th July 2006, 19:48
  5. Serial to USB converter
    By jrt4fun in forum USB
    Last Post: - 8th August 2005, 16:14
