Madness, 18F2550!
Results 1 to 12 of 12
    Have you tried the 'exact' same config fuse settings that are in your loader file
    when programming it without the loader?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Zagreb, Croatia
    Smile Solved finally!
    That helps Bruce!
    By careful comparision of every fuse programmed with and without bootloader I noticed some XINST=Extended Instruction Set Enable Bit which was dissabled in working version and enabled in non working version! In WinPicProgrammer this fuse is called "ENHCPU Extended CPU Enable". This fuse is related with some 18F specific data addressing techniques. To be sure that this fuse is my problem I reprogrammed several times exactly the same program (with other fuses the same) with XINST OFF and XINST ON and YES! With XINST ON the program is acting very strange and completely unfunctional. I try with programmer and with bootloader, symptoms are the same. So, dear friends, thanks everyone for help and write down in your notebook of 18FXXX' secrets following line:
    @ __CONFIG    _CONFIG4L, _XINST_OFF_4L
    cheers!
  1. 18F2550 timing
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 01:30
  2. Error compiling 18f2550
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 14th May 2008, 00:22
  3. 18f2550 + 24lc512
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 23:02
  4. 18f2550 'access is denied' USB error?
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 30th December 2006, 15:29
  5. 18F2550 config fuses, is my setup OK?
    By peu in forum mel PIC BASIC Pro
    Last Post: - 28th July 2006, 04:48
