I stop using ICPROG when starting using the 18Fxxxx ....
ICPROG could not understand the EEPROM- or DATA-values.
Sory guys,
my mistake due to hurry, I use WinPic programmer and yes, I checked all fuses that I programmed. The LED blinking program works very well so I think
that the programmer is doing his job very well.
To use a bootloader you add to code
and if I understand what this does correctly, it moves everything down the stack, some fixed size (4 bits, or is it 4 bytes?) anyway, what happens if you forget to comment out this code when not using bootloader?Code:define LOADER_USED 1
If as mister_e says ICPROG doesn't support 18F 2550 it's never going to program it properly.
