Madness, 18F2550!
Results 1 to 12 of 12
    Default Cool down a little bit...
    Well, do as you wish... but i doubt it will solve the problem.
    At least make sure the Config fuses are correctly transfered from MCS to your XYZ programmer software and that your XYZ software is set to program those fuses.
    I'd never trusted ICPROG and ALL freebies one anyways, and guess what? I think it's the main problem here.
    When you don't use the bootloader, how do you program your PIC, In-circuit?, on a ZIFF (or else) socket? Wich programmer/interface. Is PGM tied to GND (or at very least loaded to GND)?
    Did you do a 'programming check' once it's programmed?
    Any schematic of your stuff? ... just in case.
    EDIT: i remind Malc-C already had problem programming this PIC with software like that... no coincidence at all
    EDIT #2 : ICPROG don't have the 18F2550 in it's list... at least if their wonderful website is up-to-date...
  1. 18F2550 timing
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 00:30
  2. Error compiling 18f2550
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 13th May 2008, 23:22
  3. 18f2550 + 24lc512
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 22:02
  4. 18f2550 'access is denied' USB error?
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 30th December 2006, 14:29
  5. 18F2550 config fuses, is my setup OK?
    By peu in forum mel PIC BASIC Pro
    Last Post: - 28th July 2006, 03:48
