Combinaton Gate access
Results 1 to 40 of 48
    Then it continues on to the next IF statement...
    if ((ByteA = 8) and (combocount = %00000001)) then
        combocount = %00000011
        combocount = 0
    At this point<b> ByteA does not equal 8 (it's still 7), so it goes to the ELSE clause where it zero's combocount and starts everything from scratch again.</b> It'll never recognize more than 1 digit.
    <b>
    Then after all the IF's are done, there's nothing to stop it from opening the gate, even though it only received 1 keypress.
    </b>
    But from the sound of it, it did exactly what you told it to.
    Is that because it has not gone back to the scan routine? Should I have used goto and resume or just put return after each if...then statement? I ask this <b>not </b>ignoring your statement I should not have done it this way in the first place.<br>
    <b> Could you explain in more detail as to why? How does combocount get to the correct status to open the gate?</b>
    <b>I really appreciate it Darrel.</b>
    JS
    None of the above.
    It's because it's the Wrong Logic for the job.
    With an IF ELSE ENDIF, there are only 2 possibilities. True or False.
    And that result is based entirely on 1 expression ... (ByteA = 7) and (combocount=0)
    So essentially, you're asking it if the Whole combination is correct, by looking at just one keypress.
    Then by stacking up 5 IF ELSE ENDIF's together, since they can't ALL be true at the same time, there will always be 4 of them saying the combination is Wrong.
    Much like in real life, decisions aren't always as easy as True or False.
    Usually, you'll have to consider several different things Before making a decision.
    And those "things" may happen at different times, so you may not be able to make a decision until more information is available.
    So instead of just the True or False, Black or White. Here's the answer.
    You also need to be able to say "I don't know yet".
    This is where just IF THEN is more useful.
    Instead of only the 2 possibilities, IF THEN has Infinite possibilities.
    Granted, It's either TRUE, or it's NOT, but by not taking action when it's not true, it's the same as saying "I don't know".
    So now you can stack those up if you want, because they won't be interfering with each other by making their own decisions independently.
    They only act on what they KNOW to be TRUE.
    Here's what I mean...Still not the way I would do it, but for the sake of argument...
    combo:
        IF (combocount = 0) and (ByteA = 7)   then GoodKey
        IF (combocount = 1) and (ByteA = 8)   then GoodKey
        IF (combocount = 2) and (ByteA = "A") then GoodKey
        IF (combocount = 3) and (ByteA = 5)   then GoodKey
        IF (combocount = 4) and (ByteA = "D") then GoodKey
        combocount = 0 ; invalid keypress
    GoodKey:
        combocount = combocount + 1
        if combocount = 5 then GrantAccess
    Default Ohhhh
    None of the above.
    combo:
    GoodKey:
    I Get it, Thanks Darrel, then If you were inclined to code that way, would this be a place for select case? It seems as though the THEN Goodkey scenerio would make the combination work if out of sequence? Or would the loop cancel before combocount reaches 5 ? Oh your code works SWEET! Thanks Again.
    Joe
    You could, but it just uses more code space. It's pretty much a Select Case the way the last example is shown. But here's a Select Case version...
    combo:
        Select CASE combocount
            Case 0 : if ByteA = 7   then GoodKey
            Case 1 : if ByteA = 8   then GoodKey
            Case 2 : if ByteA = "A" then GoodKey
            Case 3 : if ByteA = 5   then GoodKey
            Case 4 : if ByteA = "D" then GoodKey
        END SELECT
        combocount = 0
    GoodKey:
    Or, just to keep things nice and confusing, you could also do this...
    Combo:
        Lookup  combocount,[7,8,"A",5,"D"], NextDigit
        if ByteA = NextDigit then
            combocount = 0
    Nope, that can't happen. You should run the program in MCSP debugger and watch what happens. After watching debuggers for awhile, you'll be able to see it in your mind, and programming will go a lot smoother. And eventually, you won't even need the debugger anymore, or the PIC. It'll run inside your head.
    No Problemo!
    Talking
    Hello to all,
    I have followed east subject and it seems to me excellent, my english is not very good but treatment for understanding what you say.
    This it is a interesting project, I am working to record the data in eeprom, when it has ready the code send.
    Talking
    It works of this form?
    @MyConfig = _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF
    @MyConfig = MyConfig & _BODEN_OFF
    @ __config  MyConfig
    '@ __CONFIG _HS_OSC & _WDT_ON & _PWRTE_ON  & _LVP_OFF & _CP_OFF
    Define PIC16F877A
    @ errorlevel -230
    CMCON  = 7
    ADCON1 = 7
    define OSC 20
    TrisD = %00000000
    DEFINE LCD_DREG PORTA
        DEFINE LCD_DBIT 0
        DEFINE LCD_RSREG PORTA
        DEFINE LCD_RSBIT 5
        DEFINE LCD_EREG PORTA
        DEFINE LCD_EBIT 4
        DEFINE LCD_BITS 4
        DEFINE LCD_LINES 4
        include "keypad.bas"
    lcdout 254,1
    lcdout 254,128,"PIC Self Test"
        DEFINE KEYPAD_ROW        4        ' 4 ROW keypad
        DEFINE KEYPAD_ROW_PORT   PORTB    ' ROW port = PORTB
        DEFINE KEYPAD_ROW_BIT    4        ' ROW0 = PORTB.4
        DEFINE KEYPAD_COL        4        ' 3 COL keypad
        DEFINE KEYPAD_COL_PORT   PORTB    ' COL port = PORTB
        DEFINE KEYPAD_COL_BIT    0        ' COL0 = PORTB.1
        DEFINE KEYPAD_DEBOUNCEMS 50       ' debounce delay = 50 mSec
        DEFINE SCAN_ONCE         1
        OPTION_REG.7 = 0        ' Enable internal crap pull-up :D
        PORTB = 0             '
        TRISB = %11110000     '
        Flags = 0
        ByteA var byte         '
        Combocount var byte
            INTCON = %10001000    ' Enable global interrupt
                              ' Enable interrupt on PORTB change
        on interrupt goto KeypadInt
        CLEAR
    Portd.2 = 0
    combocount = 0
    Init:
        lcdout $FE,1,"Press any Key"
     disable
    KeypadINT:
    @ READKEYPAD _ByteA
        TRISB=%11110000
        PORTB=0
        INTCON.0=0
        resume
    enable
    Start:
        if ByteA then
        If ByteA = 4  then ByteA = "A"
        if ByteA = 5  then ByteA = 4
        if ByteA = 6  then ByteA = 5
        if ByteA = 7  then ByteA = 6
        if ByteA = 8  then ByteA = "B"
        if ByteA = 9  then ByteA = 7
        if ByteA = 10 then ByteA = 8
        if ByteA = 11 then ByteA = 9
        if ByteA = 12 then ByteA = "C"
        if ByteA = 13 then ByteA = "*"
        if ByteA = 14 then ByteA = 0
        if ByteA = 15 then ByteA = "#"
        if ByteA = 16 then ByteA = "D"
        if ByteA != 0 then  gosub combo
            ByteA = 0
            goto init
            'else
    goto start
    combo:
    GoodKey:
    goto init ' Combination 78A5D
    GrantAccess:
    hight portd.2
    low portd.2
    ByteA = 0
    Combo1 = 0
    Quote Originally Posted by Leonardo View Post
    @ __config  MyConfig
    Define PIC16F877A
    @ errorlevel -230
    CMCON  = 7
    ADCON1 = 7
    define OSC 20
    TrisD = %00000000
        DEFINE LCD_DBIT 0
        DEFINE LCD_RSBIT 5
        DEFINE LCD_EBIT 4
        DEFINE LCD_BITS 4
        DEFINE LCD_LINES 4
    lcdout 254,1
        DEFINE SCAN_ONCE         1
        PORTB = 0             '
        TRISB = %11110000     '
        Flags = 0
        ByteA var byte         '
        Combocount var byte
        CLEAR
    Portd.2 = 0
    combocount = 0
    Init:
     disable
    KeypadINT:
    @ READKEYPAD _ByteA
        TRISB=%11110000
        PORTB=0
        INTCON.0=0
        resume
    enable
    Start:
        if ByteA then
            ByteA = 0
            goto init
            'else
    goto start
    combo:
    GoodKey:
    GrantAccess:
    hight portd.2
    low portd.2
    ByteA = 0
    Combo1 = 0
    No Leonardo,
    Use the code Darrel posted in post #9 above, or the version of it, I sent you.
    JS
    I will have to make that purchase, as I have only the freebie version which was included with PBP, as you recommend it, it must be worthwhile.
    Do you relize the power of this project? I am using it to operate the alarm on my mother's garage, another user here, for whom this was all about is using it for his gate, and it occured to me it is a useful tool to secure the table saw, bandsaw etc . . . from the children, or even adults! So since I do not have an address to send you some beer, i give you this, the knowledge that your efforts may save some little fingers.
    JS
  1. A logic gate chip with 1 ea XOR and 2 ea AND gates?
    Last Post: - 5th August 2009, 06:29
  2. Access to sim memu
    By sahin5002 in forum GSM
    Last Post: - 16th June 2009, 12:57
  3. truck gate
    By Melros in forum mel PIC BASIC Pro
    Last Post: - 13th October 2007, 14:23
  4. 18f2550 'access is denied' USB error?
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 30th December 2006, 15:29
  5. FYI - How to Access individual bytes in Word Arrays
    By Melanie in forum mel PIC BASIC Pro
    Last Post: - 20th July 2003, 22:56
