Hello mister_e,
I magnify code it works very well but I have not been able to configure my keyboard correctly. Can help me?.
For the access I should oppress 1,2,3, A,6 and they don't correspond this way the keys.
I include the files in proteus.
Thank you
[QUOTE=mister_e;32450]tons of different way to do it. You could even set your secret code in an array, read the keypad x times, compare the result with the array.
i'll try something.. maybe this will put some lights...
Code:' ' Hardware assignment ' ==================== ' ' System LCD ' ----------- DEFINE LCD_DREG PORTD ' LCD data port DEFINE LCD_DBIT 4 ' LCD data starting bit 0 or 4 DEFINE LCD_RSREG PORTD ' LCD register select port DEFINE LCD_RSBIT 2 ' LCD register select bit DEFINE LCD_EREG PORTD ' LCD enable port DEFINE LCD_EBIT 3 ' LCD enable bit DEFINE LCD_BITS 4 ' LCD bus size 4 or 8 DEFINE LCD_LINES 2 ' Number lines on LCD DEFINE LCD_COMMANDUS 2000 ' Command delay time in us DEFINE LCD_DATAUS 50 ' Data delay time in us ' ' 4X4 matrix Keypad ' ----------------- include "c:\PBP_PROG\Include_Routines\keypad.bas" DEFINE KEYPAD_ROW 4 ' 4 ROW keypad DEFINE KEYPAD_ROW_PORT PORTB ' ROW port = PORTB DEFINE KEYPAD_ROW_BIT 4 ' ROW0 = PORTB.4 DEFINE KEYPAD_COL 4 ' 4 COL keypad DEFINE KEYPAD_COL_PORT PORTB ' COL port = PORTB DEFINE KEYPAD_COL_BIT 0 ' COL0 = PORTB.0 DEFINE KEYPAD_DEBOUNCEMS 100 ' debounce delay = 100 mSec ' ' Variables definition ' =================== SecretCode var byte[5] CounterA var byte Match var byte ' ' Software/Hardware initialisation ' ================================ secretcode[0]=1 secretcode[1]=2 secretcode[2]=3 secretcode[3]=4 secretcode[4]=5 ' ' Program start ' ============= Start: match=0 lcdout $FE,1,"Enter the code" for countera = 0 to 4 @ READKEYPAD _Key if Key=secretcode[countera] then Match=Match+1 lcdout $FE,($C0+COUNTERA),"*" next if match=5 then lcdout $FE,1,"Access Granted!" else lcdout $FE,1,"Access denied..." endif PAUSE 2000 goto start
