displays
Results 1 to 20 of 20
Thread: displays
    Cool displays
    looking for something that would provide txet display for those of us that have trouble seeing small type would like to drive from a pic have good brightness and size any suggestions?
    same subject different track do the make something that can superimpose
    text on a tv screen
    again pic driven
    thanks
    Feb 2003
    Salt Lake City, Utah USA
    Default thanks
    great help appreicate you take the time
    links were perfect to get me started
    ty
    Feb 2003
    Smile
    In the last three years or so, one of the hobby journals (popular electronics, nuts and volts, circuit cellar, or every day practical electronics) had an article on adding text to video via microcontroller. I cannot remember the issue and will look - maybe someone else remembers?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Default Vfd
    Quote Originally Posted by jcleaver View Post
    text on a tv screen
    again pic driven
    thanks
    Vacuum Flourscent Displays - there are some available that are pin for pin interchangable with LCDs, if you want really large VFDs then get a POS display like the grocery store uses, cheap on ebay - rs232 compatable.
    JS
    Default lcd commands
    thinking about going to 4 line display
    know the first line 1 second line $c0
    can someone help with the 3 and fourth line commands
    dont see in manual pbp
    Mentor, Ohio
    Smile
    Hi Jack,
    Just like the RTC constants, you can set them for the displays:
    I CON 254 'Control byte
    Clr CON 1 'Clear the display
    Line1 CON 128 'Point to start of Line 1
    Line2 CON 192 'Point to start of Line 2
    Line3 CON 148 'Point to start of Line 3
    Line4 CON 212 'Point to start of Line 4
    Example:
    LCDOut I,Clr
    LCDOut I,Line1,"Breckenridge Village"
    LCDOut I,Line3+2, hex2 mon, "/", hex2 date, "/", hex2 yr, " ", HEX2 hr, ":", HEX2 MINs
    Notice the "Line3+2" This says to move the cursor in 2 spaces
    By the way, the project that this code example came from uses a Noritake VFD display. Nice and bright-you can miss it! It does draw power though, about 250ma if I remember properly.
    HTH,
    BobK
    Default lcd command
    bob thanks for the info
    however these lcd commands do not work with my pbp
    get all type of errors
    any ideas?
    appreicate your help
    example of mine is
    lcdout $fe,1 first line
    lcdout $fe,$c0 second line
    seems to be hanging up on expression line 3+2
    has this something to do with setting the display for 4 lines or?
    never mind got it was not defineing var works now
    going to glue my toes back on (ha ha)
    thanks again for your time and effort
    Which error message you get?
            '       LCD setup
            DEFINE LCD_DREG PORTB               ' LCD data port
            DEFINE LCD_DBIT 0                   ' LCD data starting bit
            DEFINE LCD_RSREG PORTB              ' LCD register select port
            DEFINE LCD_RSBIT 4                  ' LCD register select bit
            DEFINE LCD_EREG PORTB               ' LCD enable port
            DEFINE LCD_EBIT 5                   ' LCD enable bit
            DEFINE LCD_BITS 4                   ' LCD data bus size
            DEFINE LCD_LINES 4                  ' Number lines on LCD
            DEFINE LCD_COMMANDUS 2000           ' Command delay time in us
            DEFINE LCD_DATAUS 50                ' Data delay time in us
            Pause   500                         ' LCD startup delay
            LCDOUT  $FE,  1,"LINE 1",_
                    $FE,$C0,"LINE 2",_
                    $FE,$94,"LINE 3",_
                    $FE,$D4,"LINE 4"
    SpinHere:
            goto spinhere
    It's written black on white in the manual, or in the MicroCode Studio Help.
    Default error messages
    got this ok thanks for the different spin
    another question
    when i try to use mpsam for a assembler
    get a whole bunch of error messages most error 113 symble no previously defined
    complies fine not using mpsam dont know if this is a problem or not
    again thanks to all of you that help us out
    any ideas?
    example of mine is
    Hi Jack,
    if you have trouble dealing with hex use decimal like this:
    LCDOUT 254,1    ' Clears Display
    LCDOUT 254,128,"Here's how to output"
    LCDOUT 254,192,"Strings from code"
    LCDOUT 254,148,"space easily !"
    LCDOUT 254,212,"Where you put it"
    now say you want line three to move over 4 spaces, just add as so:
    LCDOUT 254,152,"space easily!" same as LCDOUT 254,148 + 4,"space easily!"
    JS
  1. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 19:30
  2. Anyone using Vacuum Flurecent Displays?
    By Art in forum General
    Last Post: - 25th March 2010, 00:30
  3. Multplexing two 7-Segment Displays with PIC16F84A
    By lawriem72 in forum mel PIC BASIC
    Last Post: - 19th July 2007, 22:27
  4. LCD Displays
    By Roland in forum mel PIC BASIC Pro
    Last Post: - 16th August 2005, 10:43
  5. Melanie's LCD displays
    By BobK in forum Adverts
    Last Post: - 24th October 2004, 12:27
