Malcolm,
I was using a 16F877A, I guess it was really comparing Apples to Oranges.
I figured I better check with a 12F675, but didn't have one handy so I used a 12F683. It was close enough to figure out what was wrong.
This get's everyone, so I should have seen it right away, but nope.
CMCON = 7 ; disable the comparators
ANSEL = 1 ; AN0 is analog, rest digital
also, You have a PWM output on GPIO.0 ... The same pin as the POT is connected to on AN0. That'll cause problems with the A/D reading.
Hope you're still interested?
EDIT: 100hz is no problem. But you'll need a faster crystal/resonator
INTRC won't cut it.
HTH,
