Recommendations - Model Train Controller - Page 2
Results 41 to 80 of 102
Threaded View
  1. #30
    Lightbulb
    There's something bad in the schematic indeed. R3 have it's use... but not at the good place. Should be in serie with the transistor base. If you short it, you'll burn the transistor...
    Anyways, i'll be back!
    Hi, Steve
    Did you notice a 1K resistor had magically appeared in series with the trans. base ??? ...
    Strong coffee needed ... Malc is a one not so easy to follow !!!
    The output schematic can be enough for this time ... let's see one problem at a time !!!
    Inserting some PAUSE ( 100-200 ms ) between inputs pollings might do something interesting here ... let's try that first
  1. Microstepper controller
    By aratti in forum Schematics
    Last Post: - 3rd January 2015, 16:52
  2. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 20:33
  3. Replies: 2
    Last Post: - 14th July 2008, 22:11
  4. Model Train controller - revisited
    Last Post: - 8th May 2007, 09:40
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
