sleep on 12f629
Results 1 to 8 of 8
Thread: sleep on 12f629
    Jan 2007
    Brazil
    Default sleep on 12f629
    hello.
    I've looked for posts discussing @sleep on 12f629 but I got nothing (I did get, but nothing helpful). I would like to make 12f629 sleep an wake on gp3/!MCLR/Vpp change (on falling edge).
    Is this possible ? How?
    Thanks!
    Sylvio
    Quote Originally Posted by sirvo View Post
    hello.
    Thanks!
    Sylvio
    How wide is this falling edge pulse?
    Do you realize that a short low going pulse on the MCLR pin is the same as a reset and therefore can be used as a wake up signal?
    Maybe use a 10K pullup on MCLR to Vdd, put your pulse into the MCLR pin itself thru a capacitor. As the pulse goes low, so does the cap, for a short period of time (depending on the size of the cap and the value of the pullup), then shortly later, the pullup resistor charges the cap back to Vdd...BAM...instant pulse generator...also, instant wake up...
    Try it and see what happens. It's worked for me before.
    Jan 2007
    Brazil
    but i set MCLR_OFF
    in my project gp3 is an input and it is connected trought the bc548 collector pin...
    and the pulse takes around 1 second...
    thanks...
    but i set MCLR_OFF
    thanks...
    Well, MCLR is an input...of a sort...
    Fayetteville Arkansas
    Did you use an interupt routine? can you post the code you used?
    Jan 2007
    Brazil
    Hi, here is all the code..:
    @ DEVICE pic12F629, INTRC_OSC_NOCLKOUT ; System Clock Options
    @ DEVICE pic12F629, WDT_OFF ; Watchdog Timer
    @ DEVICE pic12F629, PWRT_ON ; Power-On Timer
    @ DEVICE pic12F629, MCLR_OFF ; Master Clear Options (Internal)
    @ DEVICE pic12F629, BOD_OFF ; Brown-Out Detect
    @ DEVICE pic12F629, CPD_OFF ; Data Memory Code Protect
    @ DEVICE pic12F629, PROTECT_OFF
    Include "modedefs.bas"
    IGNICAO VAR GPIO.0
    IMOB VAR GPIO.1
    PARTIDA VAR GPIO.2
    AUX VAR GPIO.3
    ALARME VAR GPIO.4
    TEMPO VAR WORD 'time..
    LOAD VAR WORD
    CONT VAR BYTE
    CMCON = 7
    TRISIO = %00001000 'GPIO.3 INPUT ONLY
    GPIO = 0
    cont = 0
    TEMPO = 0
    LOAD = 55543
    ALARME = 0
    INTCON = %11000000 'enable interrupt
    PIE1 = 1 'enable tmr1 overflow interrupt
    On Interrupt Goto TE
    TMR1L=load.lowbyte
    TMR1H=load.highbyte
    IN: PIR1.0 = 0 'tmr1 flag clear
    if aux = 1 then
    SELECT CASE cont
    ' CASE 0
    ' IF TEMPO = 3000 THEN
    ' SLEEP AND WAKE ON GPIO.3 FALLING EDGE
    ' GOTO IN
    ' ENDIF
    CASE 1, 2
    IF TEMPO = 1000 THEN
    GOSUB RE
    CASE 3
    IF TEMPO = 6000 THEN
    GOSUB RE
    END SELECT
    goto in
    BRANCH CONT, [E1, E2,E3,E4]
    E1: PAUSE 100 ' THERE ARE THINGS DELETED INSIDE E1 - E4 LABELS
    CONT = CONT + 1
    T1CON = 1
    GOTO IN
    E2: PAUSE 100
    CONT = CONT + 1
    tempo = 0
    T1CON = 1
    GOTO IN
    E3: PAUSE 100
    CONT = CONT + 1
    T1CON = 1
    GOTO IN
    E4: PAUSE 100
    CONT = 0
    T1CON = 0
    GOTO IN
    DISABLE
    TE: tempo = tempo + 1
    PIR1.0 = 0
    TMR1L=load.lowbyte
    TMR1H=load.highbyte
    resume
    ENABLE
    RE: IGNICAO = 0
    IMOB = 0
    PARTIDA = 0
    TEMPO = 0
    CONT = 0
    T1CON = 0
    alarme = 0
    so, take a look on label IN, CASE 0
    i would like that to happen..
    i think it's necessary to use a kind of an interrupt handler and check the flags.. but a i dont know what flags to check..
    i think i'll need to set IOC.3 = 1 'enable gpio3 interrupt on pin chage
    i hope you help me.. sorry if that is too much..
    thanks a lot..!
    Sylvio
    If you just want to put the PIC to sleep, and wake up on keypress, you don't
    need to enable global interrupts.
    Here's something to start with.
    @ DEVICE INTRC_OSC_NOCLKOUT,WDT_OFF,MCLR_OFF
    DEFINE OSCCAL_1K 1
    GIE     VAR INTCON.7  ' Global interrupt enable 1=ON, 0=OFF
    GPIE    VAR INTCON.3  ' Port change interrupt enable 1=ON, 0=OFF
    GPIF    VAR INTCON.0  ' Port Change Interrupt Flag bit
    LED     VAR GPIO.0    ' LED output GND---/\/\/\---|<|--GPIO.0
    Key     VAR GPIO.3    ' Key input (10K pull-up w/switch to ground)
    X       VAR BYTE      ' G.P.
    CMCON = 7             ' All digital
    GPIO = 0              ' Clear port on boot
    TRISIO = %00001000    ' GPIO.3 input, rest outputs
    GIE = 0            ' Disable global ints
    GPIE = 1           ' Enable port change int
    IOC.3 = 1          ' Int-on-change for GPIO.3 enabled
    X = GPIO           ' Take a snap shot of port on boot
        X = 10
        REPEAT
         TOGGLE LED        ' Toggle LED
         X = X - 1
         PAUSE 250
        UNTIL X = 0
        @ SLEEP            ' SLEEP until Key is pressed
        WHILE Key = 0      ' Wait for Key release
        WEND
        GPIF = 0           ' Clear port change interrupt flag
        GOTO Main
    You take it from here. Pretty much all you need is in the data sheet, and it's
    simple to understand if you take your time...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2007
    Brazil
    hey Bruce, thanks!
    That is what i was trying to get..
    I'm going to update my code and then i'll post de results...
    thank very much!
    Sylvio
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. 12F629 Won't SLEEP
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 24th August 2008, 13:08
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 11:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
  5. Programming 12F629 low power (Sleep)
    By Warrier in forum mel PIC BASIC Pro
    Last Post: - 29th November 2004, 15:45
